Old 08-17-2022, 11:53 AM   #1
evan
evan's Avatar
Removing parking brake cables ok?
The parking brake on my '79 C10 hasn't worked for as long as I've owned it. It's never been an issue for me. All the cables are still run under the chassis though. Would I cause any problems by removing them? Is there some thing at the drums that needs them there to keep working normally? Do you still have yours intact?
Evan B.
evan is offline   Reply With Quote
Old 08-17-2022, 02:32 PM   #2
Dead Parrot
Re: Removing parking brake cables ok?
Mine still works. If the park brake pedal ratchets and releases normally, your issue could be as simple as adjusting the cables. There is an adjustment nut on the cables on the driver's side.
Dead Parrot is offline   Reply With Quote
Old 08-17-2022, 04:36 PM   #3
damnyankee36
damnyankee36's Avatar
There's no problem removing the cables. Just keep in mind using the parking brake is one of the brake shoe self-adjusting methods. The other is when you back up and come to stop.
It wouldn't hurt every once in awhile to drive in reverse a little on the fast side and firmly hit the brakes to adjust them.
damnyankee36 is offline   Reply With Quote
Old 08-17-2022, 05:25 PM   #4
cadillac_al
These trucks actually have an emergency brake. They will drag and slow you down in an emergency. When they went to rear disc brakes, the emergency brake function was so weak they started calling it a parking brake because it would be of no help in an emergency.. Mine always work great.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 08-18-2022, 06:50 AM   #5
Hammered 77
Hammered 77's Avatar
Mine won't ratchet any more but I haven't looked to see why. Probably should take a look and get it working again.
Hammered 77 is offline   Reply With Quote
Old 08-18-2022, 08:30 AM   #6
geezer#99
geezer#99's Avatar
Are the cables hooked up inside the drums?
Likely easier to fix them than remove them.
geezer#99 is online now   Reply With Quote
Old 08-20-2022, 02:23 PM   #7
Pontiac1976
Pontiac1976's Avatar
evan:
First I would back off front cable near the trans, to see if the cable is frozen at the e-brake peddle cable covering(sleeve) just below master. If that cable move freely in out then that good still. It most likely the two rear cables at the cable covering(sleeve) where it is frozen by rust. If the cable is fared it no good. You have to take the drums off the see the cable end in the drum connection ( like a bike brake cable) If you do not know how to do drums brakes look up a manual 1973-80 or a few drum brake Youtube video on drum brakes 73-80 trucks. I you can't do it take it to a shop that has some one that know older drum brakes.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 08-20-2022, 02:33 PM   #8
Pontiac1976
Teck Tip: If you want the keep the cable lasting a longer time is to get as much white greases in the the (sleeve) liner covering to keep out water help lube the inner sleeve, keep it for wearing out letting metal contact. Once plastic inner sleeve gone and water droplet get in there does not dry out, rust again. Should do this one ever season, @ the three spots.
Old 08-20-2022, 03:17 PM   #9
Just call me Sean
Just call me Sean's Avatar
I don't think it's very smart to remove the parking brake.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-28-2022, 09:41 PM   #10
85/Silverado
85/Silverado's Avatar
I have no room to install one, with a 4-link and now disc breaks on the rear.
I'm just SOL Sure wish I could though.
85 Silverado LWB Fleetside 383 Stroker
86 Custom Deluxe SWB, Pro Street LSX
85/Silverado is offline   Reply With Quote
Old 08-28-2022, 11:00 PM   #11
geezer#99
geezer#99's Avatar
Have you looked into pinion mounted Park/emergency brakes?
Old 08-28-2022, 11:11 PM   #12
SunSoaked
SunSoaked's Avatar
It will take as much time to remove it as it will to just fix it the way its supposed to be. Geeez
SunSoaked is offline   Reply With Quote
Old 08-28-2022, 11:59 PM   #13
85/Silverado
Do you still have to run cables? I have to install a new Ford 9" housing so I would like to instll the PB. at the same time.
Old 08-29-2022, 12:19 AM   #14
geezer#99
geezer#99's Avatar
The ones I’ve seen use a hydraulic hose or a cable.
Old 08-29-2022, 01:39 AM   #15
Accelo
Accelo's Avatar
It is common to have the rear cables freeze up. Easy to tell, just pull on them, from under the truck, and see it they return. It eliminates the other possible issues. They are cheap and easy enough to find. Getting the cable out of the backing plate is the hardest thing about replacing them.
I would fix them. Parking brake is like a parachute, it's nice to have if you need one.
Cheers
Accelo is offline   Reply With Quote
Old 09-01-2022, 11:00 AM   #16
hatzie
Moderator
hatzie's Avatar
The drum brake adjusters will not work without the parking brake lever on the shoe.
For the people that say the cables freeze up. I have never had parking brakes freeze up and stop working when I was driving a vehicle at least once every month or so. Exercise the parking brake often. Use it when you park the vehicle. Even automagic transmission vehicles. That's what it's for.
I grew up driving manual transmission vehicles. It's just plain unsafe to leave them in gear unattended. I've had water run into the fuse panel on vehicles and activate the starter motor. My 75 Scirocco high school beater lurching into the back of Moms' new Impala crunching the trunk lid and back panel & smashing out her taillights in the middle of the night during a thunderstorm cured me of leaving vehicles in gear for parking. If I'd set it in reverse, as I often did, it would've lurched down the driveway, across a main road, and over the cliff into the river if it didn't get hung up in the brush or cause an accident on the road. Mom and my stepdad were more than a little perturbed. One of those things that I'll never forget even 40 years later but I bet they don't remember at all.
The added benefit of exercising it is the parking brake mechanism spins the star wheels on the automatic adjusters so you don't have to tweak them as often to get decent performance from your drum brakes. Properly adjusted rear drums will work quite well. I'd rather have front discs but properly working rear drums work just fine.
Cables are cheap and easy to replace. Illustrations showing routing and part numbers are in the GM parts books.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
