08-22-2022, 02:02 PM | #1 |
Parking Light / turn signal question?
Does the parking light / turn signal socket, take a 1 or 2 filament bulb?
What is the correct bulb number ? |
08-22-2022, 03:11 PM | #2 |
Moderator
Re: Parking Light / turn signal question?
It would be 2 as the ground is the plug body and there are 2 wires going to them as indicated on the wiring diagram.
08-22-2022, 07:59 PM | #3 | |
The replacement bulb socket is plastic with 2 wires, one black, and one white. I don't see any reason to ground the metal housing, as the bulb socket, is plastic Do the dark blue, and light blue, wires connect to the black and white wires comming from the bulb socket.? |
08-22-2022, 08:19 PM | #4 |
What's it look like inside?
Two contacts in the bottom would be a park light and a signal light, and use an 1157 bulb or something. The socket holder itself would be metal, and make the ground where it connects. One contact in the bottom would be signal only, no park light, and the black would be your ground. Use an 1156 bulb I think.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
08-22-2022, 08:32 PM | #5 | |
I does have two contacts on the inside of the socket. Do I connect the light blue, and dark blue wires coming from the harness to the black & white socket wires, and ground the parking light metal housing?? |
08-22-2022, 08:59 PM | #6 |
Moderator
That is what I would do.
08-23-2022, 09:10 AM | #7 |
I believe Skinny G is correct so you may have the wrong socket. It should be metal for the ground with 2 contacts in the bottom and use a 1157 bulb.
08-23-2022, 12:30 PM | #8 |
PROBLEM SOLVED !!!
The lights work perfectly now Thanks for all who offered advice on this thread. |
