Old 08-24-2022, 12:23 PM   #1
freds
engine timing
rebuild 1967 c10 chevy pickup, replaced new 350 chevy engine and using the old harmonic balancer, why am i not able to zero out the balancer to TDC specks. way out of the limits range white marks. no matter which way i turn the distributor. is there such thing as tbe harmonic need to come with the specific engine ?. also causing engine to get very hot.
freds is offline   Reply With Quote
Old 08-24-2022, 12:33 PM   #2
72SB
Re: engine timing
your old damper likely has slipped making the timing mark on it useless. They are wear/replacement items
Is your current damper hub keyed?
You want a keyed hub/damper and one with timing marks on it or use MSD timing tape the correct size for your diameter damper. It comes in a sheet for around $7 and you just stick on the size you need
hot engine would indicate timing is to retarded
72SB is offline   Reply With Quote
Old 08-24-2022, 12:36 PM   #3
geezer#99
geezer#99's Avatar
Re: engine timing
You might find the info you need here.
https://www.crankshaftcoalition.com/..._TDC_lines_SBC
geezer#99 is online now   Reply With Quote
Old 08-24-2022, 01:11 PM   #4
geezer#99
geezer#99's Avatar
Re: engine timing
And some more info.
https://www.crankshaftcoalition.com/...op_dead_center
Old 08-24-2022, 03:46 PM   #5
jgr
Re: engine timing
You should never switch a harmonic balancer from one engine to another. Run the numbers on the engine in the truck and then buy the correct one for that engine, they do not cost that much! The wrong balancer will take out your bottom end.
jgr is offline   Reply With Quote
Old 08-24-2022, 04:02 PM   #6
Rickysnickers
Rickysnickers's Avatar
Re: engine timing
I'd highly encourage you to purchase a new balancer. They can be had rather inexpensively, https://www.summitracing.com/parts/s...make/chevrolet
Old 08-24-2022, 04:16 PM   #7
Wrenchbender Ret
Re: engine timing
Some 350 engines had the timing marks straight up. You looked down between the water pump & timing cover.
If that is what you have you will need to remark it like Geezer says.
Wrenchbender Ret is offline   Reply With Quote
Old 08-24-2022, 04:43 PM   #8
LS short box
Re: engine timing
The best way to confirm the timing mark on the balancer is to buy a piston stop and screw it into the #1 spark plug hole. Slowly rotate the engine over until you touch the piston to the piston stop. Then mark it using the timing tab as a reference. Then rotate the engine the other way until the piston touches the piston stop and mark it. In the middle of those two marks will be top dead center. Then go from there adjusting the timing.
Old 08-24-2022, 07:07 PM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: engine timing
I've had that timing tape get distorted by Carb Cleaner and come off from engine heat. It's not permanent.
You can get your Harmonic Balancer rebuilt by the Damper Doctor [ damperdoctor.com ] but for an engine as common as the 350 SBC, it's probably cheaper to get a new one. If you had a more obscure engine, the Dr would be the choice.
Old 08-24-2022, 07:10 PM   #10
rockyrivermark
This is great advise.
rockyrivermark is offline   Reply With Quote
Old 08-24-2022, 07:30 PM   #11
Sheepdip
Sheepdip's Avatar
Re: engine timing
This is the guy I used to get the "CORRECT" dampener for my particular engine. Very knowledgeable as he should be.
https://www.damperdoctor.com/
If you want to time it temporarily to run use a vacuum gauge.
This is assuming everything is correct/right with all parts used in the rebuild.
Hook the vacuum gauge to manifold vacuum, run your motor at approximately 2500 rpm while turning/adjusting your distributor to read the highest vacuum, then slightly back (retard) it off and lock it down.
Sheepdip is offline   Reply With Quote
Old 08-25-2022, 09:25 AM   #12
72SB
Re: engine timing
in lieu of buying a damper with etched timing marks....
any non clean surface or one that is exposed to cleaners like carb cleaner over any sticker....yeah it is going to come off
Applying the timing tape to a clean damper and it will stay....does on mine. YMMV
