Old 08-27-2022, 08:57 PM   #3101
67C10Step
67C10Step's Avatar
Re: What did you do to your truck today.The 3rd chapter
Double post
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-27-2022, 11:46 PM   #3102
Sheepdip
Sheepdip's Avatar
Originally Posted by 68bowtie View Post
I trimmed in my carpet today and installed the dash pad and belts. The ACC carpet was a damn good fit in general, just a bit more wrinkle than I’d like over the trans hump. But I can live with it. I expected way worse.
Attachment 2214598
NICE!!! Don't know that I personally have ever seen that color combo on these trucks.
Sheepdip is offline   Reply With Quote
Old 08-28-2022, 12:36 AM   #3103
68bowtie
68bowtie's Avatar
Thanks guys!
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
68bowtie is online now   Reply With Quote
Old 08-28-2022, 02:37 PM   #3104
72c20customcamper
72c20customcamper's Avatar
Got the inside and various other parts painted today . I never made it to my granddaughters party . Picked up mom on Thursday and she developed a bad cough Friday . Sure enough tested positive for Covid so she’s staying till Friday at least . So I worked on the truck yesterday and today .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-28-2022, 02:39 PM   #3105
72c20customcamper
Couple more
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-28-2022, 02:44 PM   #3106
LNP
Sorry to hear about your mom getting sick. Truck lookin good. Nice paint job
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 08-28-2022, 03:04 PM   #3107
72c20customcamper
She has only a cough slight fever Friday night but that’s gone , All in all pretty mild been three full days and I’m not showing any symptoms but waiting till wed to go out and about .
Thanks I really like single stage on a use truck no need for BC/CC . Also helps having a good gun . I replaced my old Seta with a Tekna Pro Lite not cheap but sprays sooo nice. Now on to the doors and fenders yay! Sarcastically
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-28-2022, 06:36 PM   #3108
LNP
Yea I say not cheap $600 gun. I got the 3M Accuspray paint gun to do my truck. It worked real well.
Harley
Old 08-28-2022, 07:48 PM   #3109
72c20customcamper
Didn’t pay that much for it . Think I paid 475 was some Black Friday thing online a few years ago
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-28-2022, 08:40 PM   #3110
sfont66
sfont66's Avatar
I cleaned out the Pcv port and baffle on the valve cover on my 5.3 l33 Ls. Recently swapped into my 72 C10.
From what I have read, the port can get plugged up on the 2005-2007 engine, so it was time to check it out……
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 08-28-2022, 08:57 PM   #3111
72c20customcamper
Torn on doing an LS swap or install the 402 I have into the 68 Anniversary .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-29-2022, 12:00 AM   #3112
sfont66
sfont66's Avatar
I would be torn as well, after finishing the swap, I do like the power ( I want more) it starts instantly, and with the 6 speed manual transmission freeway driving is now possible. But…. A big block would be awesome, I do love the simplicity, and how clean an engine bay can look, without all the extra wires needed for the LS. So I guess I need 2 trucks, I love both the modern technology, as well as the old school simplicity. One with each, that way I could enjoy each one for what they are…
Old 08-29-2022, 12:49 AM   #3113
'68OrangeSunshine
'68OrangeSunshine's Avatar
I installed a new Cigar Lighter in my '68 C/10 Stepside. The old one shorted out when the spring-loaded positive tip of a plug [going to a recharger solar panel] broke off and crossed the ground to the hot. Fried up a lot of wires under the dash. I had the Dash Panel and Heater Controls off or hanging down to get a good look. While the Red line feeding the Cigar Lighter burned its insulation off, none of the other wires near it were burned. Some had charred lengths of Cigal line stuck to them. I chackefd all the lines, and reinforced any singeing with E-tape. T prevent a repeat, I spliced an inline fuseholder w/ 15 A fuse between the Cigar tab on the fuse block and the lighter socket.
While I had the Speedo cable loose, I disconnected the other end at the SM465 -- pulled the flex cable out of its sheath and dusted it with graphite lube. I think I noticed a 2 Mile bump on the Odometer. It was reading 234 before. After I reassembled the Dash, Ash Tray, Heater Controls and tested the Cigar Lighter for function, the Odo read 236.
Go figure?
Since my Fuel Gauge has been reading Empty lately, I'm dependent on accurately guessing my mileage and fuel intake level.
I did a 20 mile run to test and check my systems and the Cigar socket, as a port for my GPS. I still notice a little wobble in the Speedo needle at 60 MPH (indicated) [62 GPS]. I may need more miles to settle in and read right.
Old 08-29-2022, 12:38 PM   #3114
72c20customcamper
Cleaned up the instrument cluster. Before and after
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-29-2022, 12:44 PM   #3115
72c20customcamper
Now I need to spray the column . In search of paint color again
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-29-2022, 02:21 PM   #3116
ohboy321
ohboy321's Avatar
Today I replaced a broken rocker arm stud. I first attempted the job with the head still installed, but ended up pulling the head off yesterday. I first tried cutting new threads and using stacked washers to pull it out, but the threads gave out before it started moving. While still in the truck, I then tried welding a stud on top of the broken one to use for pulling it, but wasn’t able to get a good weld, mainly because of the location and my inexperience with welding. Welding in an assembled motor is scary, so I pulled the head, removed all the valves, and then was able to get a good enough weld to pull the broken stud. I tapped the hole, threaded in a new stud, reinstalled all the valves, and will start putting the motor back together tomorrow.
This is the second stud that broke after installing a mild lift cam (.454/.454) last year, and based on the location of the break on both, which was just at the base of the threads, it looks like the slots in the stock rocker arms were not long enough causing this issue. I now have new rocker arms with longer slots and should know if I solved the issue soon. Pictures are the first stud that brok and the second one I pulled today.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 08-29-2022, 05:22 PM   #3117
a Good Man
a Good Man's Avatar
Before & after
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is offline   Reply With Quote
Old 08-29-2022, 05:31 PM   #3118
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by 67C10Step View Post
The original switch on the wiper/washer runs the new pump. With the hoses no longer running through the firewall there was a perfect pass through for the wiring harness I built plus the fuel level from the rear mounted tank.
The old click clack pump had a sort of timer but this one will run only when you hold the button in. But it squirts way better.
I did the exact same set up wired to the stock switch. I love it.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-29-2022, 06:07 PM   #3119
72c20customcamper
Originally Posted by a Good Man View Post
Before & after
Pretty truck .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-29-2022, 06:10 PM   #3120
72c20customcamper
Dash is coming along . I used duplicolor Arizona Beige for the column and the top of the dash it looks the same in pictures but is much darker and I put a two wet coats and then misted it to kill the gloss.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-29-2022, 07:46 PM   #3121
'68OrangeSunshine
AZ Beige, Huh? Looks a lot like the old interior Irridescent Fawn Poly they used a lot in '67 and '68.
Old 08-29-2022, 07:49 PM   #3122
72c20customcamper
The dash itself is Saddle fawn poly as is the rest of the truck . The Duplicolor is a couple shades darker hard to see with the lighting
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-29-2022, 08:18 PM   #3123
'68OrangeSunshine
OK Thanks.
I need to repaint my original steering wheel. I've had a SeaFoam Green one on as a loaner,* while I rebuilt the wheel. Now it only needs to get repainted.
But I can't get Fawn easily anymore.
If I go with another shade, I'll have to paint the steering column too. That leads to Mission Creep, and I don't want to 'down' a daily driving work truck.
[*And it looks like hell.]
Old 08-29-2022, 08:37 PM   #3124
72c20customcamper
OK Thanks.
This is the color .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-29-2022, 08:43 PM   #3125
72c20customcamper
Now I’m a little confused looking at older pictures is the door suppose to be this color ? Much darker than the dash
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
