Alternator Size
Hey fellas,
I have 90 amp alternator on my SBC 350 with HEI, Vintage Air, FiTech EFI & Pump, 17" Electric Fan, and radio and I am having a lot of issues with the truck just staying running. I am thinking about going to a bigger alternator. What amp should I go to? Thanks! |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Alternator Size
Do you know the total amps your pulling at any one time in a normal day? That is, have you added the amps up on the above listed items?
Moderator
Re: Alternator Size
If you don't get an answer here I can see about moving this to the Electrical section - http://67-72chevytrucks.com/vboard/f...splay.php?f=64
Re: Alternator Size
I run a Mechman in Dodge 370 amp. They have a 170 with V belt or rib. Custom ones can be made to order
https://www.mechman.com/alternators/...let/1963-1985/
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
It's Better With Nitro
Re: Alternator Size
Like Rocknrod LVPhotos mentioned, add up your amp draw to get a better idea of what you need. I run a 160 amp Hi-Torque alternator that kicks on at a low RPM. I run a lot of accessories that draw significant amps: MSD Digital 6 ignition, 2 HO radiator fans, 1 HO trans cooler fan, Vintage Air AC unit, MagnaFuel EFI pump, air suspension compressor, etc.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Re: Alternator Size
Might want to measure the voltage at several places such as battery, fans and alt.
Re: Alternator Size
Pirate:
Few of questions: * What size pulley are you running on crank? Performance (i.e. smaller) crank pulley results in alternator turning slower and water pump running slower. Causes problems for street car with cooling and charging. * Is cooling fan running continuously or only when engine exceeds temp? Running it all the time needlessly taxes charging system. * What is battery voltage when engine is running? Short answer is 90 amp alternator is unlikely to be the source of your problem. Hope this helps. Regards Steve |
#8 | |
Re: Alternator Size
Take your belt off and see if it runs any better off the battery. Motor will not cool, i.e no fans or water pump. However, running a short time on a fully charged battery should not hurt anything and it may eliminate the alternator as the source of your problem. |
![]() Join Date: Sep 2020
Re: Alternator Size
I agree with vn63, you’re running a bit of a load, fuel oump, ac, etc, personally I use minimum off 100 amp with less than that…the difference in cost for a bigger/better alternator is minimal…think of it this way, a 6 cylinder will move your vehicle, and use more fuel because it works harder doing the same thing as a properly tuned v-8….
| Bookmarks |
