How to test power window voltage and where to supply power?
I'm trying to fix my slow passenger side window in my 87 truck. It's slow going up and down, and it often needs a person to help it go all the way up. I have already replaced the window motor and the regulator with new AC Delco stuff. So we can rule that out.
If anyone knows what all the various colored wires do that connect to the passenger side switch, please let me know. I have the Power Probe (if any of you are familiar with that thing) and it can send power through the end. But I'm not one to go sending power down wires that I don't know where they go. Bad idea. I searched around and I did find this, but I think it's for an 83 model, but maybe it's the same as 87? Anyway I'm not so good at reading electrical schematics. Looks like the passenger side switch is at the very bottom but I'm not certain where to plug in the volt meter prongs to test the voltage. http://www.73-87chevytrucks.com/tech...werwindows.gif |
Re: How to test power window voltage and where to supply power?
This on the site,: https://67-72chevytrucks.com/vboard/...d.php?t=545416
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Robert Olson Transport
![]() Join Date: Oct 2002
have you tried simply greasing the tacks and the window felts
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
#4 | |
If anyone knows, I'd like to know how much voltage drop you're supposed to see when the windows are in operation. My guess is that you don't want to see it drop below 11v when you're pressing the switch. Not sure though. Anyway if I can determine that maybe I can just fix an electrical problem and avoid having to tear down the whole door and rebuild it. |
Moderator
![]() Join Date: Oct 2008
AGS extra fine dry graphite powder in the flocking on the tracks and wet silicone lube like Sil Glyde in the regulator pivot points and rollers.
Slow motors can be from the motor itself. The aromatics in the 40-50 year old grease can outgas leaving heavy grease that doesn't flow into things. You can disassemble the motor from the regulator, clean out the old grease, and re-lube the worm gear. The motor ground path is through the motor body. This means the ground path travels through your hinges. Adding ground straps between the door and the chassis can beef up the ground. Unlike modern vehicles that use relays to offload the high current motor from the switches... The stock squarebody switches carry the full motor current load so the contacts get pitted and carry less electrons.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#7 | |
Moderator
You can use Lithium in the regulator. Relays to offload the current from the switches would go a long way. GM used a relay on the power locks but not the windows. These windows were never speed demons.
I have these two greases. Should I use the one in the tube?
Moderator
Either should work in the regulator mechanism. Grease attracts dirt so don't go overboard with it and don't use it in the felt flocked tracks.
You should be able to get extra fine dry graphite powder from the hardware store where you buy Hillman nuts-n-bolts and get keys cut. Ace, Tru Value, ...
#10 | |
I need to determine if my vent window uses 1 piece or two piece window seals. I was hoping you would know. I had mine replaced about 10 years ago, and I can't remember which ones I used. I remember buying them at the Chevy dealer's parts counter. Don't remember anything about 1 piece or two piece. I don't want to screw up and buy the wrong ones. But I can't be sure it doesn't already have the wrong ones on it. They were so road noisy that I ended up using silicone to seal up the gaps. So I'm afraid I might have the wrong ones. Thank you |
Alright I went ahead and bought both of those things. To clarify, you also use the Sil Glyde in the roller tracks, correct?
#12 | |
![]() Join Date: Oct 2014
https://youtu.be/9YwM0piQ-OE
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
Moderator
In and on the rollers.
