Old 08-31-2022, 04:55 AM   #1
popeyestruck
popeyestruck's Avatar
Steering wheel options
What are the bolt on options for a smaller steering wheel on a stock column? 59 chevy
popeyestruck is offline   Reply With Quote
Old 08-31-2022, 07:28 AM   #2
Hcb3200
Re: Steering wheel options
Basically any steering wheel you want. Stock to aftermarket to custom.
They make kits to bolt them right up.
Hcb3200 is offline   Reply With Quote
Old 08-31-2022, 10:31 AM   #3
popeyestruck
Thanks that makes it easy
Old 08-31-2022, 05:43 PM   #4
mr48chev
mr48chev's Avatar
You want a flat spoke wheel though. Dished wheels will put the wheel too close to your chest and too uncomfortable for your arms.
Also without power steering you don't want a wheel that is too small. Too small and your arms get stronger and your chest muscles hurt.
Most GM car steering wheels from the same time frame will go right on the truck column but the horn may not work.
My ongoing truck projects:
Old 08-31-2022, 06:00 PM   #5
Southcity
Southcity's Avatar
Good info provided by mr48chev. Other considerations would be looking into a tilt column or even a shortened tilt column (stock steering wheel or aftermarket). This is a nice way to retain a stock steering wheel, improve driver comfort and room. Another potential option is reducing the size of a stock steering wheel. There are several threads on this board that provide great detail on both of the above.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 08-31-2022, 08:43 PM   #6
mr48chev
mr48chev's Avatar
I've got an "I took out of something I scrapped" steering wheel in the 48 that I can't remember what it came out of but it might be Vega GT and that bugger is right up in my chest. I put it in after a guy gave me way more money than I thought it was worth for the 59 Corvette wheel I had in it.
I have a 53 Bel Air wheel for the 48 but may go with a 51 Bel Air wheel.
Old 09-01-2022, 12:38 AM   #7
vintovka
vintovka's Avatar
Once put a fancy new wheel on the 54 before it had Power Steering. Being smaller than the stock wheel it made the truck very, very hard to steer around corners. Tight turns like off the scale muscle wise. Immediately put the stock wheel back on and sold the new one.
Should say whatever wheel you choose it seems to get closer to your gut with age.
vintovka is offline   Reply With Quote
Old 09-01-2022, 04:36 AM   #8
popeyestruck
I'm putting power steering in it once CPP gets it off backorder (3months)
Old 09-01-2022, 10:32 AM   #9
vintovka
vintovka's Avatar
Smart move.
Old 09-01-2022, 12:04 PM   #10
mr48chev
mr48chev's Avatar
If you are going to put power steering in it and either modify or change the column your options are as big as your imigination.
As long as the rim of the wheel doesn't get closer to you or change position up or down except in the name of your personal comfort life is good.
I tried to buy a wheel for a 51 Bel Air off a guy on FB last night because I really like the looks but I got scared off by the methods he wanted to be paid by.
I've Got a Nardi wood wheel that was made for Miatas that I bought used from somewhere in Asia off Ebay a few years ago that I really like. I bought an adapter hub off another Ebay seller to put it on my 71 column.
Just do your figuring and measuring so that the wheel you choose fits in the right spot.
I still had the 68 Bench seat that my friend Gary gave me in the truck when the photo was taken. It's got a Silverado split bench now.
