Old 12-09-2019, 11:25 PM   #76
1rippen6
Re: So when in 1972 did GM start installing single wall tops?
My info may be incorrect, I just looked through your posts and #41 appears to have the long leg on the top strip and the CST panel strip.
1rippen6 is offline   Reply With Quote
Old 12-10-2019, 11:14 AM   #77
Blazer690
Blazer690's Avatar
#57 also shows a long lip. Mine is a flint 05 1972 CST with a grill in the dash and has a cwt with a short lip. It's history doesn't indicate any change. Maybe they came each way?
Blazer690 is offline   Reply With Quote
Old 12-10-2019, 02:40 PM   #78
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Good eye - any idea if this style will indeed clear the panel trim? Maybe this style reflects an early design as the example in #41 is an earlier 1x wall example?
Old 12-10-2019, 02:43 PM   #79
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Huh, just read your post. Another good catch. This one too is an earlier 1x wall. I wonder if these rub against the bedsides if the seals wear out?
Old 03-16-2020, 01:48 PM   #80
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a St Louis example that based upon sequence number was probably assembled toward the tail end of the model year. It's clean but given it now has a tilt, tach, FM radio not originally equipped with it's hard to say that the single wall top reflects its original top but including here for future reference.
The red/dark saddle is a neat combo. More pics here: https://www.ebay.com/itm/1972-Chevro...4AAOSwNelebuU8
Old 03-16-2020, 04:54 PM   #81
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Pete
Here is a 72 CST I just cut up. Not sure where it fall in the numbers but it had a single wall
And it only had holes in the bed rails for single wall. No dual holes for Double
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 03-16-2020, 09:09 PM   #82
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks a ton for posting. That’s great to know. Was under the impression that all bedsides had provisions for both tops but seems that’s not the case. Fun to flesh out these details.
Old 06-25-2020, 08:19 PM   #83
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Early (09/71) Flint Jimmy with a double wall. Seems like a complete truck probably with its original top. VIN TKE182F513973
https://eauclaire.craigslist.org/cto...148276161.html
Old 08-31-2022, 09:08 AM   #84
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here’s a Sept 7, 1971 Flint assembled Blazer. Did not receive an optional top but the dash lacks a speaker grille and the assembly sequence number of 7417 falls in range of other such examples that also used a 2x wall top.
More photos here: https://bringatrailer.com/listing/19...et-blazer-111/
Old 08-31-2022, 03:41 PM   #85
1rippen6
Did you notice the long seat belt on the passenger side, do you think that is because of no back seat or has it been replaced?
Old 08-31-2022, 09:44 PM   #86
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I did see that. Was thinking it’s a replacement piece but that’s just a guess. Pre-refurbish photos would be great to see. Have you seen any others with the flanges on the front axle rather than manual locking hubs?
Old 08-31-2022, 10:05 PM   #87
1rippen6
No, I haven't, I was curious about that also.
Old 11-12-2022, 06:56 PM   #88
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Double wall St Louis seq 159156 - still chasing any solid examples of a St Louis 1x wall example
Posted here: https://bringatrailer.com/listing/19...let-blazer-44/
Old 11-13-2022, 08:08 PM   #89
52napco
My K5 is a Flint build w sequence number 172264 and a 1X
52napco is offline   Reply With Quote
Old 11-18-2022, 10:39 AM   #90
moore_rb
I posted in UtahBoy's Bringatrailer Ad that I thought I remembered seeing the overhead dome lights being listed as part of the Cheyenne/Highlander Package for 1972 Blazers, which would have lent evidence that the single-wall top (with dome lights and the fancy chrome rails) may have been correlated to the Cheyenne/Highlander option package on the SPID...
But now I am doubting my own memory- I think what I was actually remembering was the overhead cargo light, which was listed with the Cheyenne package on Pickup trucks for 72.
It appears from this thread that there were Blazers built for 72, which came out of St Louis, and included the Cheyenne trim package, but also had the double wall top, without overhead lights.
moore_rb is offline   Reply With Quote
Old 11-18-2022, 02:25 PM   #91
DeadheadNM
Carpe manana
DeadheadNM's Avatar
“Courtesy lamps” were standard on 72 model year K5s when a top was ordered and included in the RPO z78/z79. As such, the lamps aren’t called out on the SPID. Double wall equipped examples (St Louis assembled and early Flint 72s) used the courtesy lamps under the dash. Only single wall tops had the lamps in the top.
I believe Cheyenne equipped pickups had courtesy lamps as part of the package (with the cargo lamp) but I’d have to double check that.
Old 11-29-2022, 12:11 PM   #92
jaredyocum
jaredyocum's Avatar
anyone have any measurements on the difference between single and double wall bolt pattern ?
jaredyocum is offline   Reply With Quote
Old 08-15-2024, 09:19 AM   #93
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Here's a very well optioned, early Flint assembled 1972 2wd survivor with a 2x wall top and the speaker for the am/fm bolted on below the dash. Build sequence is 106728 indicating late August or early September build.
Presently on FB for sale in MN
