Old 08-23-2022, 06:01 PM   #1
the67Beast
Active Member
the67Beast's Avatar
Hole Size in Cowl for Factory Antenna
What size is the factory antenna hole; located on the cowl for the factory antenna? And is there a template somewhere that can be used to position for drilling? My truck had no radio and therefore no hole in the cowl for the antenna. Want it to be in the correct location. Thanks for any assistance guys!
the67Beast is offline   Reply With Quote
Old 08-23-2022, 08:49 PM   #2
402Bowtie
402Bowtie's Avatar
Re: Hole Size in Cowl for Factory Antenna
I'm not sure of the hole size, but you would probably come out ahead in money and time if you sold your current cowl and bought one with the hole. The one without the hole is rare and commands a better price than the style with the antenna hole.
402Bowtie is offline   Reply With Quote
Old 08-23-2022, 09:05 PM   #3
the67Beast
Active Member
the67Beast's Avatar
Yeah I went back and forth on that idea several times until I started pricing the cost of the re-pop cowls. Dang everything has gotten expensive. Wonder how much mine is worth without the antenna hole? Enough to buy a re-pop... I just don't know. But, mine is original to my truck and straight so that's why I'm leaning toward keeping it and just drilling the hole. Wonder if I could find someone close by with one that has the factory hole. Then I could just swap. I am planning on painting it anyway.
Old 08-23-2022, 09:26 PM   #4
dagnabbitt
dagnabbitt's Avatar
Radio delete cowls are really desirable, with original paint especially.
If you don't care if it is factory I suggest a magnetic antenna. If you are getting satellite radio, even easier to hide. Just a suggestion, it is your truck.
EDIT - I know I just said it is your truck, but if you are planning to do that to the barn find in your avatar, please reconsider.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 08-23-2022, 09:46 PM   #5
jocko
jocko's Avatar
If planning to paint it anyway, I'd personally opt for an original GM cowl with the hole (more common) off the parts board before going the repop route (and then selling yours - you'd likely come out $ ahead). Drilling the hole correctly in the curved cowl surface is a little more tricky than it looks.
Old 08-23-2022, 10:06 PM   #6
CG
BlahBlahBlah
I think the radio delete cowls aren’t as popular as the used to be. Was a time when they were listed on the board they went quickly. Seems like the last one I saw on the board took a bit to move. Too bad you’re not closer I have a bunch of cowls and would give you one. Course the cost of shipping and packing something that size makes it out of the question.
Old 08-24-2022, 12:36 AM   #7
pjmoreland
pjmoreland's Avatar
I bought a very nice original style antenna from GMCPauls.com and it came with templates for drilling the hole in the cowl as well as the hole in the cab. A previous owner had drilled the wrong size holes in the wrong places, so I had to patch them and re-drill. The cowl hole is 1-1/8", but it is oval, and it has a notch. I've attached the instruction sheet and templates (see .pdf links below).
File Type: pdf Radio Antenna Instruction Sheet, p.1.pdf (256.2 KB, 59 views)
File Type: pdf Radio Antenna Instruction Sheet, p.2.pdf (261.3 KB, 57 views)
pjmoreland is online now   Reply With Quote
Old 08-24-2022, 11:07 PM   #8
the67Beast
Active Member
the67Beast's Avatar
Exactly the info I needed! Thanks for your assistance with this PJMoreland. I'll post some pics of the before and after whenever I get done.
Old 08-25-2022, 01:23 AM   #9
Hatzman
Hatzman's Avatar
Ill trade ya cowls! I would prefer not to have the hole.
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 08-30-2022, 05:20 PM   #10
the67Beast
Active Member
the67Beast's Avatar
Wish we lived a bit closer Hatzman. I suppose its cheaper to just drill the hole.
Old 08-30-2022, 05:24 PM   #11
the67Beast
Active Member
the67Beast's Avatar
And I might as well turn this into a tutorial. So here are the photos of this little project. I found that I am going to need to buy a smaller file for the notch next time and a bigger step bit (will be less filing). Pjmoreland, your work looks way better than mine! Ended up getting my notch a tad too big, but I think it'll work OK. Ya'll enjoy the photos. (Added Note: When printing off the template, make sure you scale it properly for the size paper you are printing it on. The hole should measure 1-1/8" just like Pjmoreland said.
Old 08-31-2022, 09:12 AM   #12
1967-C10
1967-C10's Avatar
Lol...just welded mine closed ! would have traded you in a heart beat !
1967-C10 is offline   Reply With Quote
Old 08-31-2022, 05:29 PM   #13
the67Beast
Active Member
the67Beast's Avatar
Yessir... swapping would have been ideal, but due to the size of the cowl, drilling the hole beats the shipping charges any day 1967-C10. Shipping to Hatzman in northern California was coming in between $40 - $50. To Texas might have been a bit more economical.
Old 08-31-2022, 07:48 PM   #14
jocko
jocko's Avatar
That turned out very nice!
Old 08-31-2022, 08:27 PM   #15
CG
BlahBlahBlah
This is from a very old contest I had on the board. Don't remember who posted it ...
Old 09-03-2022, 02:34 PM   #16
54blackhornet
54blackhornet's Avatar
I have a radio delete cowl I removed from a no option 68 GMC. Stupid me kept the cowl but left the radio delete plate in the truck when I sold it. I have installed the cowl on three different 67/72’s. It’s the first thing folks talk about when I drive it…
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
