![]() Join Date: Sep 2005
GMC hubcap identification
Moving some stuff around and came across my stash of GMC hubcaps. The ones on the right came off of a 1974 truck. The ones on the left came off of a 1982 truck. I am trying to find out the correct years for each set. These are all the larger hubcaps (3/4, 1 ton), but I don't believe that makes any difference. Thanks in advance. Unfortunately I don't have a complete set of either one.
James |
Re: GMC hubcap identification
The front-hub hole diameter varies between a d44/10-bolt (3/4-ton) and a d60 (1-ton) axle. I can't say which one those are, though.
There were also large-hub d44 axles back in the day, but I don't know much about those. https://www.hubcaps.org/chevtruck.html http://67-72chevytrucks.com/vboard/s...d.php?t=813170
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
![]() Join Date: May 2010
The front caps look like 3/4 ton. Here's 1 ton.
It only has original paint once |
I have the 3/4 ton caps on my 84 Sierra. I think they used them through the 73-87 models
That was part of my confusion. According to the link, they did not start with the "new" style hubcaps until 1976. The 1973-1975 stayed the same as the earlier style.
James |
![]() Join Date: Jan 2001
The 69-72 GMC 3/4 caps the center hub area was inverted out and painted black with the orange GMC letters.
Then on the 73-76, same style hubcap but the center hub is not inverted and painted like yours with unpainted hub center with orange GMC letters. Then in late 1976 they went with the more flat version aluminum cap. Paint wise this was true on both the 1/2 and 3/4 ton style hubcaps which are different diameters about 10" and 12 ". To answer your question, the 3 caps the left with the open caps are 1977 up to 1991 square body and the 3 full caps on right are technically 1973-76 GMC.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 factory #'s V8 stepside project '72 Cheyenne K20 50k original '72 CST Blazer K5 owned 30+yrs '73 Sierra swb 4x4 '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" Last edited by HOTFUN; 09-10-2022 at 12:29 PM. |
On another subject with these caps, does anyone know if they can be polished, buffed or whatever? I have one that is i good shape and still shiny, but the 0ther 3 or hazy, and white colored. I tried steel wool(0000)on them with no luck. I will have to replace at least 2 eventually since someone used one as a bb gun target, and the other is pushed in in the center.
#8 | |
James |
