Old 09-02-2022, 06:22 PM   #3176
LNP
Re: What did you do to your truck today.The 3rd chapter
Nice door gaps. Looks like a nice fit.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 09-02-2022, 06:46 PM   #3177
72c20customcamper
72c20customcamper's Avatar
Original door to the truck that helps a lot
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-02-2022, 07:13 PM   #3178
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by pjmoreland View Post
Those Fresnel lenses in the pic are in my possession and are installed on my truck now. Here are the lines from the parts catalog. Looks like 5958622 (Fresnel) might have been from 66-70, and then 5961260 (parallel) were from 71-75.
That is a much better look, IMO. I wish you joy of them.
Maybe I'll post a WTB for the Fresnel B/U Lenses [NOS]. We've seen what 50 years exposure to the AZ Sun does.
Old 09-02-2022, 07:15 PM   #3179
Steeveedee
Who Changed This?
Steeveedee's Avatar
It's amazing how differently some things fit. My '82 Regal was parked in the street and someone backed into the left rear door, caved it in, and took off. It was easier to buy another door at Pick-Your-Part on a holiday for $12.50 than buy body work. It required a massive amount of adjustment to be made to fit. I'm not a body man. The difference surprised me quite a bit.
~Steven
Simi Valley, CA
Old 09-02-2022, 09:51 PM   #3180
'68OrangeSunshine
Originally Posted by '68OrangeSunshine View Post
OK. I had to look. No markings on the Driver's Side bracket. On the forward face of the Passenger Side bracket, there is a mark. Could be an angled ''V'' or ''7'' or ''L''. In daylight, I'll rub some graphite in the mark and shoot a pic.
OK. Here's the shot. I'm not sure if the graphite trick worked. [I'm not Sherlock Holmes] The graphite stuck to the whole surface since I sprayed it with PB Blaster to loosen the mounting nuts the other day.
It's right by the pigtail hook. At about 200X you can just make out a capital L.
Old 09-02-2022, 09:53 PM   #3181
pjmoreland
pjmoreland's Avatar
Is it down there by the wire retainer hook?
pjmoreland is offline   Reply With Quote
Old 09-02-2022, 10:03 PM   #3182
'68OrangeSunshine
Yeah. About an inch out from the hook at 11 o'clock.
Think I have a warranty claim?
Old 09-02-2022, 11:40 PM   #3183
Steeveedee
Who Changed This?
Steeveedee's Avatar
Probably not, but you might interest the FBI in working on their data recovery repertoire. They've probably not done a rubbing on a backup light bracket, yet.
~Steven
Simi Valley, CA
Old 09-03-2022, 12:09 AM   #3184
'68OrangeSunshine
That's a pretty specialized skill. I'll wait for a better offer from the NSA.
Old 09-03-2022, 05:58 PM   #3185
72c20customcamper
Worked on the inside of the door today .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-04-2022, 01:05 PM   #3186
LNP
Nice work
Harley
Old 09-06-2022, 02:40 AM   #3187
pjmoreland
pjmoreland's Avatar
I acquired a functional truck AM/FM radio recently. The AM/FM band selector switch has a little string attached to it that rotates a drum that has both the AM and FM frequencies displayed on it. I broke the string changing bands. I ordered some replacement string on eBay designed for this application and installed it today. The drum is operational again. I had to fabricate a new little clip to crimp the ends of the string together because the original one fatigued and broke when I bent it open. It's missing the AM and FM labels, so I've got some on order. Here's a video of the drum in action.
https://youtu.be/V9JgVtNmHLM
When I first received the radio, the lens appeared to be missing the Delco script, but I discovered the lens was installed upside down so it was hidden.
Old 09-06-2022, 04:37 AM   #3188
BLP1969
The, I don't know the correct name for it, plate under the dash that the brake/clutch pedals rest stop, the plate that has the rubber stops on it when released, has disappeared on my 1969 truck. Does anyone have one to sell, or can tell me where to purchase one, and the correct name for it?
BLP1969 is offline   Reply With Quote
Old 09-06-2022, 10:29 AM   #3189
LNP
Its the pedal stop plate. Heres a photo that LocDoc posted in another topic on this forum. And a link to a place I think makes them. If they dont maybe someone on here will have a used one they could sell you or you might try junk yards.
https://4speedconversions-com.3dcart...m/3941730.html
Harley
Old 09-06-2022, 11:55 AM   #3190
cab4word67
cab4word67's Avatar
I installed the caster mod and the bump steering mods this weekend on my 67, now I have to give it the new alinement and I will be done again
[IMG]<a href="https://ibb.co/3NpSVDw"><img src="https://i.ibb.co/85rPGWJ/MWHB4065.jpg" alt="MWHB4065" border="0"></a>[/IMG]
cab4word67 is offline   Reply With Quote
Old 09-06-2022, 11:57 AM   #3191
cab4word67
cab4word67's Avatar
I installed the caster mod and the bump steering mods this weekend on my 67. Had to trim some off the back side of the A arm and on the bump steer mod I cut my adjusters and added about 3-3/4" to make them reach the heim joint. Now I have to give it the new alinement and I will be done again
Thanks everyone for all the info on these mods.
Old 09-06-2022, 10:23 PM   #3192
cab4word67
cab4word67's Avatar
I did my alinement today and found I have 9.5 deg caster on the left side and 11 deg on the right side. Camber is .25 on both sides. I cant go less on the caster on the right so I mite increase the driver side. Anyone out there see a problem with them being 1.5 deg different?
Well I could I guess, we will see tomorrow.
Old 09-07-2022, 03:02 PM   #3193
72c20customcamper
Since it’s raining I decided to soak some parts in Rust 911 very impressed with the two day soak . I intentionally left half out to see the results .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-07-2022, 03:32 PM   #3194
72c20customcamper
Should be easier to take apart . The vent widow would hardly move prior to soaking
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-07-2022, 10:31 PM   #3195
cab4word67
cab4word67's Avatar
dang that is some cool stuff
Old 09-08-2022, 06:27 PM   #3196
72c20customcamper
Truck is wearing me down guess it could be I’m only a week out of Covid too. I really want to drive it before the snow flies I should have these in paint hopefully by Saturday . Passenger door is already in prime so I just need to do the passenger fender and hood .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-08-2022, 06:47 PM   #3197
HO455
HO455's Avatar
That's a big gain of caster. How far forward did you drill the new index holes?
I moved mine 3/4" and my caster came in at 5.30*.
RIP Bob Parks.
Old 09-08-2022, 07:02 PM   #3198
cab4word67
cab4word67's Avatar
I moved the hole 3/4 just like was said to. But I think my tubular uppers have 4 degs built in from CPP. The truck is driving like a dream now. We are going to do it to the 65 next, mabe then he can drive straight lol.
Just looked they have 5 degrees built in.
Old 09-08-2022, 07:44 PM   #3199
LNP
Seems like a whole lot of caster to me. If everything is even it probably does drive nice. If the arms had 5 degrees made in them then I wouldnt have moved them at all. Just my two cents.
Harley
Old 09-09-2022, 08:58 AM   #3200
HO455
HO455's Avatar
That makes sense. Personally I would definitely try to get both side within half a degree of each other.
RIP Bob Parks.
