Old 08-02-2004, 08:50 AM   #1
jorgensensc
jorgensensc's Avatar
What year were the long Spark Plug wires?
I bought new wires for the truck yesterday and 3 were too short. I seem to remember a thread that discussed which year vehicle to get plug wires for so they would be long enough. I thought it was an older corvette, but I'm not sure. I thought someone was using the wire splitters that connected to the block at the back and they said a certain year corvette had the correct length wires. i'm just looking for anything that would be long enogh. 60.00 for wires to get fried on the manifold isn't going to work. Any help would be greatly appreciated.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 08-02-2004, 09:48 AM   #2
smokekiki
Mike
smokekiki's Avatar
Ithink it is the 70's small block vettes.Up to 73 for points and74 and newer for hei.I but Taylor wires from summit and cut them at what lenth I want.They are good wires and come in colors others don't have.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 08-02-2004, 09:53 AM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Depends on whether you have HEI or not. No HEI, get the stock wires for a 67-72 truck smallblock. HEI, get 75 vette wires. here are the vette wires using HEI on a stock ramhorn equipped smallblock
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 08-02-2004, 10:00 AM   #4
jorgensensc
perfect!! thanks guys, i knew I could count on you to come through for me. i'm a little afraid of screwing up the wires if I try and do them myself. 75 vette it is!!!
Old 08-02-2004, 11:37 AM   #5
toddtheodd
The oddest Todd around
toddtheodd's Avatar
75 vette. Thank you. That helps me out tremedously as well.
Todd
toddtheodd is offline   Reply With Quote
Old 08-02-2004, 10:55 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
Isn't it a shame that Jeff(CPNE) doesn't remember how to run his wires the "stock" way. Let's ask the judges..........yep, they all say that qualifies as a custom modification. Let's just hope that picture is a stock photo and not one of Jeff's engines.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 08-02-2004, 11:21 PM   #7
kwmech
I just did a conversion to HEI and the GM part # for the delco wires is 12043740. I always run the wires on top of the valve covers and curl them around the cyl heads.
Old 08-02-2004, 11:22 PM   #8
Rakort
Well, what is the stock way? I want to see because I plan on doing the stock wire thing shorty myself!
thanks
Rakort is offline   Reply With Quote
Old 08-03-2004, 08:38 AM   #9
jorgensensc
I just got the Accel part # 4041 for my truck. They are 8mm (I wanted 8.8mm, but they had to order them and I didn't have time to wait for them). I had to put my own boots on the ends (what a pain in the a$$) , but they look great and were plenty long enough!! I was able to route them all down behind the back of the block ( like the pick above) using the wire loom attached to the back of my block on both sides. I also used the looms included and they look really good. My old wires ran over the valve covers, but I kinda dig the way this really cleans up the engine. The engine looks less cluttered now, and that's hard to do with A.C. hoses and all the other hoses, and you can see the shiney valve covers now. Thanks again CPNE!
Shawn
Old 08-03-2004, 09:21 AM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
That is the stock routing. Those looms that bolt to the back of the block are factory. Down behind block, then up under the stock ramshorn manifolds. The problem is with the non-stock HEI. If you ask for plug wires for an HEI equipped truck engine they are too short to route correctly. :p The only rams horn equipped HEI smallblocks were mid-70's vets. At least it's got the stock accessory brackets, valve covers, no headers, and is in the correct V8 position
Old 08-03-2004, 03:13 PM   #11
68 Suburban
68 Suburban's Avatar
Ok, i just did this last night. I have HEI and I hate the angle plugs, especially with my ram horns. I bought plugs for a 76 Pickup with a 454. They have the straight boots on the plug ends and are more than long enough.
The best part, is that they are only $15.99 with a lifetime warranty at Autozone.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 08-03-2004, 03:28 PM   #12
Dean
Dean's Avatar
Here are how mine are routed with the HEI using all the original shielding, clips & etc
Dean is offline   Reply With Quote
Old 08-03-2004, 03:50 PM   #13
skokie
skokie's Avatar
Dean
Thats a nice setup. Is that all stock?
skokie is offline   Reply With Quote
Old 08-03-2004, 08:10 PM   #14
da-burb
"Ochre Ogre"
da-burb's Avatar
Jeff, the way I have seen has the wires in a clip on the oil pan rail and the 1,3 and the #2, 4 wires actually run between the block and the motormount on their way up to the plugs. And yes, the back wire holders are indeed correct. I was just funnin' you for the routing of the front pairs of wires. It looks like Dean has his the way I know of.
Old 08-03-2004, 11:33 PM   #15
toddtheodd
toddtheodd's Avatar
Ok, so what is the correct wires to use on an HEI setup with hooker long tube headers? Does anybody have any pics of the correct way to wire those up as well?
Old 08-04-2004, 06:51 AM   #16
Dean
Dean's Avatar
Yes, my routing is pretty much stock and it is a pain to get the wires between the motor mount and the block. You really need to pull the mount off or the wire boot off to get it thru there.
