Old 09-09-2022, 01:35 PM   #3201
cab4word67
cab4word67's Avatar
Re: What did you do to your truck today.The 3rd chapter
Both sides are now equal at 9 degs caster and .25 camber. Truck drives nice.
just a note if you buy CPP upper and lower tubular control arms each has 5 degrees built in yielding 10 degrees total caster, so I think that my 9 is just fine for my application.
cab4word67 is offline   Reply With Quote
Old 09-09-2022, 06:29 PM   #3202
72c20customcamper
72c20customcamper's Avatar
Just cut in the white hard to see but it came out real nice . Tomorrow it’s main color time .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-09-2022, 06:34 PM   #3203
72c20customcamper
Just need to figure out where to put my tape line for the break between the saddle and white on the fender
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-09-2022, 06:44 PM   #3204
cab4word67
cab4word67's Avatar
that sure does look good, you arent painting them outside?
Old 09-09-2022, 07:31 PM   #3205
72c20customcamper
The small spots . Tomorrow I’ll be using a screened in room not perfect but I lost the booth I used . Friend sold the shop
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-09-2022, 07:58 PM   #3206
cab4word67
cab4word67's Avatar
nothing wrong with that as long as there is no wind the day you spray. Preaty cool idea.
Old 09-09-2022, 09:59 PM   #3207
Steeveedee
Who Changed This?
Steeveedee's Avatar
Got to love single stage lacquer. I've painted several cars in the driveway in southern California early in the morning when there was no wind or dew.
~Steven
Simi Valley, CA
Old 09-10-2022, 08:01 PM   #3208
72c20customcamper
Can you still buy acrylic lacquer?
Painted the main color today .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-10-2022, 09:50 PM   #3209
Steeveedee
Who Changed This?
Steeveedee's Avatar
Not any more, except for Dupli-Color "Paint Shop" lacquer at O'Reillys. My experience with their metallic blue on my '68 Skylark was less than stellar. I sold that in '14, though. I'd suspect that the red, yellow and black that I had bought would still be OK. I still have those colors, as I was going to paint flames on it. I dropped the driveshaft on my head when installing the 350 Buick engine and trans while removing the Chevy power, flinched and hit my head on the concrete driveway. I got a concussion which took about 6 months to clear up. During that time, I sold it for about 1/10th of what it was worth. That's what brain damage can do to you, I guess.
~Steven
Simi Valley, CA
Old 09-11-2022, 12:46 PM   #3210
72c20customcamper
Noticed this when I pealed the tape . The number 47 is stamped right into rear door pillar . Strange I didn’t see this before .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-11-2022, 08:16 PM   #3211
BLP1969
Originally Posted by Liz View Post
Chapter 2 is now complete, bring on 3. What did you do to your truck today?
I ordered a clock to go where the vacuum gauge goes to complete my gauge cluster, it already has the tach.
BLP1969 is offline   Reply With Quote
Old 09-12-2022, 10:49 AM   #3212
A1971Blazer
A1971Blazer's Avatar
I found a 10 bolt front axle cheap with the gear ratio I wanted so I figured I could rebuild it cheaper than just re-gearing my D44....
A couple of rainy days and it's going back together now
all replaceable parts from the inside out are new...
pressure washed inside and out...plugged all openings, sandblasted and wire brushed the housing...primed , painted and partially re-assembled...
I'll install all the outer stuff once it's in the truck
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-15-2022, 07:39 PM   #3213
72c20customcamper
Hung the drivers door today and started to put shiny stuff on . Fender and full assembly of the door tomorrow. Only truck I have that the ampmeter works
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-15-2022, 08:14 PM   #3214
72c20customcamper
Visors cleaned up nice.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-16-2022, 07:19 PM   #3215
72c20customcamper
Did some more on the truck. Soon I won’t be able to work on it , as it is now I have to pull it out of the barn to work on it not enough room in the barn with all the posts . Lock came out ok some really deep scratches. When I went to work on the window and regulator found one of the rollers was toast . Should have looked more closely so it’ll be a few days till I get a them . Start on the passenger door tomorrow
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-16-2022, 11:49 PM   #3216
Smitty
Smitty's Avatar
Thumbs up Re: What did you do to your truck today.The 3rd chapter
Looking better every day. Coming along nicely, this labor of love!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 09-16-2022, 11:55 PM   #3217
Louisvillekytruck
Great work Mark looks beautiful
Louisvillekytruck is offline   Reply With Quote
Old 09-18-2022, 08:18 PM   #3218
pjmoreland
pjmoreland's Avatar
I cut some pieces out of the dash of a truck at the wrecking yard today to use as templates for cutting A/C vent holes in my dash.
pjmoreland is offline   Reply With Quote
Old 09-19-2022, 03:44 PM   #3219
72c20customcamper
Probably be able to sell them after your done with them
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-19-2022, 03:45 PM   #3220
pjmoreland
pjmoreland's Avatar
Yes, I hope so. Will feel less wasteful for cutting up a dash if multiple people can use them.
Old 09-19-2022, 03:47 PM   #3221
72c20customcamper
Not much done today was doing firewood but I managed to get one door card done . The little black speck is a bug but the panel was dry when it landed . Used leftover paint from my 04 Tacoma .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-19-2022, 05:42 PM   #3222
LNP
You're doin some kickass work there
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 09-19-2022, 06:05 PM   #3223
72c20customcamper
Thanks . It’s going to be a nice truck not a show piece but a nice driver.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-19-2022, 08:05 PM   #3224
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
Long time no see guys! Haven't done much, heck just drove the truck for the 1st time in months yesterday. Nice to just start her up and go :-)
I did get a NOCO GENIUS2D Trickle Charger installed a bit ago (from Amazon), though I primarily didn't go out to get one for the truck but one for my daughter's '69 Austin-Healey Sprite (that is basically a MG Midget). Her car sat so long the battery died... I'd wished she'd get her drivers license already and get it out of my garage. Kids these days LOL
Anyways, I figured if I was going to get her a trickle charger, I'd get one for my truck too. I mounted it on the right side of the battery tray (radiator side of the tray), there was just enough room to get its little mount on the battery tray. It actually ended up being the perfect spot as the wires for the battery and power were just long enough to get where they were needed. Didn't take the little charger very long to switch from pulsing red to solid green for a fully charged battery (its basically brand new). The Sprite, still blinking red after hours - so I am pretty sure the battery is weak (though my big charger said it was fully charged).
If there was one complaint, it is the length of the power cord - it would have been nice if it was double the length. On the Sprite, the battery is up behind the motor on the firewall. So even with taking the charger to the max distance from the battery, the power cable can't reach out to the grill/bumper area. I am going to need to make a power cable extender so we don't have to open the hood to hook up the charger.
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 09-19-2022, 09:32 PM   #3225
Steeveedee
Who Changed This?
Steeveedee's Avatar
Nice! It's good to keep batteries maintained like that. I have two batteries in my travel trailer that were new 5 years ago, and checked out good awhile back when I had other electrical issues worked on. My trailer is at a storage lot, and the batteries are on the maintainer in the garage.
~Steven
Simi Valley, CA
