Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 09-12-2022, 01:06 PM   #1
_Ogre
_Ogre's Avatar
magnetic copper welding plug
i've never seen a commercial version of magnetic copper welding plug
i have a brass slug or flatten a copper pipe for plug welding holes
this one happens to be on sale at amazon
https://www.amazon.com/gp/product/B07ZG59SHV/
shop air compressor timer
Old 09-12-2022, 02:18 PM   #2
mongocanfly
mongocanfly's Avatar
Re: magnetic copper welding plug
That is cool Ogre..!!..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 09-12-2022, 04:21 PM   #3
mr48chev
mr48chev's Avatar
I think I have had that one on my wish list for a while. I'd say that the first hole in a firewall that you use it to back up while you weld the hole up will pay for it. I've got the spoon type one that I got off Ebay but unless you can reach around to hold it or have a helper it isn't all that great.
I'd have to go out and count them but have something like 30 holes that my uncled drilled in the box of my 71 GMC to weld up. I went out and looked and there 16 holes in the drivers side of the box to weld up 12 being on top and 4 for the J hooks and probably 17 on the passenger side as my uncle drilled a hole from the inside through the inner panel and the outer panel to bolt a small tool box inside the bed at the back. I remember Dad buying him a 3/8 drill for Christmas one year.
My ongoing truck projects:
Old 09-13-2022, 01:49 PM   #4
1project2many
For years I've used a block of steel that's roughly 1" thick and 4" square. I've also used cast iron as a backer. That tool above would be nice to have.
1project2many is offline   Reply With Quote
Old 09-13-2022, 02:23 PM   #5
_Ogre
_Ogre's Avatar
I'd rather have a buddy on the other side. By the time you get around to move it and back, you and the bud would have welded 4 holes closed ��
Old 09-13-2022, 02:24 PM   #6
Rickysnickers
Rickysnickers's Avatar
This is a good find Ogre!! I'm going to move it to Tools so it hits a larger audience.
Old 09-13-2022, 10:06 PM   #7
Getter-Done
Getter-Done's Avatar
Thanks for sharing, Ogre.
I have made a lot of my own tools.
Like we all do.
For that Money
Just ordered some
The early bird gets the worm,
85 Chevy K-20
Old 09-14-2022, 09:32 AM   #8
dsraven
cool tool, I shouldda had one when it was firewall time, lol. I have several flattened copper pipe pieces of different shapes and contours and a thick piece of brass that takes longer to heat up
it should come with a step drill so the old hole can be cleaned up to bare metal and sized for the round slug to fit well. that way you don't have to custom fit every filler slug, just drill the hole to fit the slug. welders series sells "unholes" for cheap, prolly others do too. I sometimes use a magnet to hold the slug due to no helpers. it only works for the tack because the magnetic field distorts the weld and then there is porosity to grind out and re weld. tack, remove magnet, hammer/dolly to get flat, tack again, hammer/dolly......you know.
I have used a regular uncoated nail sometimes. it has a nice shank to hold while you weld, then cut that off when done. the shank helps absorb some heat too
I have a C clamp that I cut off so it is only 1/2 a C. it has a magnet attached to the cut off part so it can stick to the surrounding metal and not distort the weld so much, then the threaded part can be screwed down to fit whatever height you need. it has uses as well.
https://welderseries.ecwid.com/Unholes-p50202282
Old 09-14-2022, 09:34 AM   #9
dsraven
hey Rickysnickers, maybe you could drop a quick link to the tools section. thanks.
Old 09-14-2022, 10:03 AM   #10
Rickysnickers
Hi Dennis, yes, I moved it here
Old 09-14-2022, 01:38 PM   #11
mr48chev
mr48chev's Avatar
Why would you think it needed to be moved? it was information for the group not anything anyone was selling?
Old 09-15-2022, 09:23 AM   #12
Rickysnickers
I moved it because it was tool related and others from different forums might see it and think the same thing, "I could use one of those" or "Hey, that's cool." Therefore, it's shared with the rest of the community.
Old 09-17-2022, 05:48 PM   #13
truckster
truckster's Avatar
I got mine today. It looks like it's made pretty well. For $15 I don't think it would be worth my time to build one. I'll try it out this coming week.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 09-17-2022, 06:18 PM   #14
Getter-Done
I got mine also.
I really like it.
I have already thought of extra attachments for it. (Imagine that).
I will post pictures when I borrow the hardware from work to make it.
85 Chevy K-20
Old 09-19-2022, 10:45 PM   #15
mr48chev
mr48chev's Avatar
After we hashed over that I went on Amazon and ordered one and found out that I had exactly enough Amazon points to pay for it with nothing out of pocket.
They are rather small so they will fit in tight spots and appear to very well made. In fact the company that makes them makes a whole line of welding tables and accessories https://stronghand.stronghandtools.c...e_model=AGK320
Old 09-19-2022, 10:56 PM   #16
Getter-Done
I really like this addition to my Welding Tools.
The small screw on the Copper end is M4 metric/ Thread.
The other articulating side is M8 /Thread.
I am already planning to make attachments.
85 Chevy K-20
