Old 09-21-2022, 08:36 PM   #1
matthew.mcmullin
ACC carpet too big?
So I've been working on the interior of my 72 GMC.
I have the mass backed carpet kit from ACC and when I went to put it in it seems way too big. There is about 2 " of bubble in the hump area.
I don't think that there is any way this is going to look good once it is installed.
Ideas / suggestions appreciated.
matthew.mcmullin is offline   Reply With Quote
Old 09-21-2022, 09:11 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: ACC carpet too big?
The carpet says it’s for a turbo 400 and low tunnel. From what I understand the 400 has a high hump . Looks like your truck is a low hump
Edit : the ACC site has two options for transmission auto 3spd and the 400 . Not sure what that means as the 400 was a 3spd too. But they do list the two option .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 09-22-2022, 12:39 AM   #3
FirstOwner69
FirstOwner69's Avatar
Looks like they sent high hump carpet in a box labeled low hump. My 69 C20 with a 350 and TH400 has a low hump and the carpet fits great.
Jim
FirstOwner69 is offline   Reply With Quote
Old 09-22-2022, 08:50 AM   #4
1967-C10
1967-C10's Avatar
high hump, wrong carpet set.
1967-C10 is offline   Reply With Quote
Old 09-22-2022, 12:44 PM   #5
Willie Makeit
Willie Makeit's Avatar
turbo 400 came in low hump cabs
Willie Makeit is offline   Reply With Quote
Old 09-23-2022, 09:04 AM   #6
72c20customcamper
Wasn’t aware of that
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-23-2022, 09:54 AM   #7
68bowtie
68bowtie's Avatar
Big block auto or manual trans or 4wd were the triggers for high hump.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 09-24-2022, 10:29 PM   #8
v30crewcab
v30crewcab's Avatar
I ordered one for an in tank cab. they sent me one for no tank in cab. I just stuck the extra up the front of the tank for now, as I plan to remove it later. seems they are good at getting orders slightly wrong. Hopefully its easy to get them to swap it for your.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 09-25-2022, 11:13 PM   #9
SkidmoreGarage
This thread comes up every year, ordering from Rock Auto exacerbates the problem.
For anyone else reading along, the ACC carpets generally fit just ok. If you get one that seems off, that's normal. Make sure to lay it flat in the sun before you start and if you want it perfect, get some upholstery cement, jute pad, and get creative.
SkidmoreGarage is offline   Reply With Quote
