#276 |
Don't be sorry, I was mentioning to help other folks who might answer .
I'd skip the service brake interlock . The GM starter is dead simple : most (why I'd need a picture) has a terminal you connect the wire from the key that comes live when you're in the 'START' position . That's it .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
#277 | |
Re: 50 years ago I was given this USAF 54 3100
#278 |
Glad it worked out, I have no idea of your abilities so my methods might not make sense to you .
Unless your truck is overheating and spewing clouds of steam do not replace the thermostat with a lower rated one ! . Gasoline engines run best at close to boiling temperature, this is why they have pressure caps ~ every pound of pressure raises the boiling point of plain water by 3 degrees, adding properly mixed (60% coolant 40% distilled water, NEVER use tap water) coolant raises the boiling point as well as preventing corrosion . I'm amazed (shocked ?) that no one else chimed in on your questions . I'm an elderly retired Journeyman Mechanic who's extremely well covered in all the basics of running a classic so ask away if you dare trust my foggy memory . BTW ~ as you can tell by my signature, my name is Nate .
#279 |
I think the problem is that the fan shut off point is same as the thermostat (195F). I need to replace the upper hose anyway so its kind of an experiment. Also having been recently "inducted" into the VFW and DAV may be doing low speed parade stuff and overheating is a concern. As you can probably tell i'm an old registered engineer who loves modify and tinker.
#280 |
GOOD ! .
Then you'll want to do it correctly . Leave that thermostat along and measure the front of the radiator and buy the largest electric fan that will fit, power it via a relay and wire the relay live all the time . I did this on my old 1949 Chevy 3100 with a 235 and even here in the Desert it never boiled over . Often when I parked it I'd get 20' away from it and the heat soak would switch the electric fan on (why you need to wire it live) and folks would yell at me " ! Hey ! you left your engine running !" . Consider putting a tattle tale lamp on the dash somewhere to indicate when the fan is actually running, use this to gauge if you need to install a lower temperature thrmostat . You won't but it'll give you another fun little thing to do that's dynamic in nature .
#281 |
Already have the biggest most powerful fan i could get at the time
Spal 30102113 Puller Fan (16In High Performance Race ; Curved Blade; For Use W/ 40Amp Fuse at 13V), The kicker is they say not to use it as a full time fan. Not sure why that's the case. Its wired direct and will cool the stopped hot engine fast. Keeps running on the 195F thermostat driving. Only other options include adding a shroud as fan only covers a little more than half radiator surface. Big fan is noisy too. Will add a "fan on" light soon. |
#282 |
O.K., if this fan located as high up as it can be or the middle ? .
Sounds like you're well on your way . 40 amperes is a lot of current, I wonder why it draws so much . Does the engine still have a mechanical fan ? .
#283 |
Its a racing fan so lots of draw. Mounted in mid radiator. No mechanical fan (wish it did)
#284 |
Well ;
Two fans can create unwanted turbulence in the air flow through the radiator . The fan needs to be mounted as far up as possible for maximum effect .
#285 |
Thanks wish i knew about fan location before. Will look at moving it up. New upper hose, thermostat and housing should be here today and in soon.
Have given up on replacing mechanical alarm switches with magnetic. The ones they sent off amazon are huge and incompatible with steel doors. I think i can ground the alarm to the chassis and still have it work with the main negative cutoff. |
#286 |
Yeah ;
I too wish I knew (or remembered) half of what I know now, back when I was a young pup, eager but clueless .That's the nature of the beast, some learn as they go along, others refuse to learn anything they don't currently know . I crave knowledge . Moving the fan up should be dead easy . Maybe door jamb contact switches for the alarm ? . No need to make thinks complicated . Courtesy lamp switches work well and junkyards are full of them in various types, sizes and so on .
#287 |
Most of the parts are here so got started. Drained radiator, Pulled old hose, thermostat and housing. 40+ year old upper Hose was so soft it tore in process. While hose was out moved fan up to radiator top from middle – At least 6”. Seems the new Radiator zip tie mounting kit was missing from box so Made do with parts from old kit. Just drilled holes on old front and rear pads and used regular zip ties to hold them in place. Cut head off new ties to lock them in place. Used 1” section of waste tie thru the inside recycled retaining pad as a safety measure against pull thru. Using a large zip tie to hang fan down from filler neck worked great to hold fan in position while installing ties. Later cut and removed it,
Replaced thermostat with the 180F and drilled a couple 1/16” 'burp” holes as many recommended. Old thermostat was leaking and was installed with only an O ring – no gasket or sealer. New Housing came with just a gasket. Used blue RTV on surfaces just in case. New 22” x 1.5” hose fit fine but forgot the replacement Radiator I installed over 23 years ago had a 1.25 neck, Cut a 2” section from a spare 1 ¼ hose and used it as a sleeve inside the new 1 ½ hose. Fastened both ends with Dual Stainless bands (installed in opposite directions). Will have to wait a week until things calm down here to refill radiator and test results, |
#288 |
Well ;
You're making progress here . The auxiliary fan mounting kits are sold by NAPA and others, should be easy to find one if you still need it . The by-pass holes are a good idea, I don't always drill them because in theory a cooling system in good shape shouldn't need them . You've not yet mentioned overheating and plumes of steam so I'm thinking you just don't like it to run near boiling point . RTV is bad stuff in a cooling system ~ I hope you simply wiped on a thin coating on each side of the gasket with your finger . Those blobs that moosh out also moosh in and get caught in the radiator's tubes and cause cold spots in the radiator and also poor engine cooling .
#289 | |
Re: Water Jacket Fun
The sole issue is the fan running all the time. No overheating issues. I used just enough to cover the gasket. Auto Zone sells a small packet in what looks like a catsup squeeze pouch. Helps not to use too much. Just finished reassembling whole front apron cover. Had a metal fatigue break on one side of the upper radiator support frame. Took forever to fab up repair strap as needed to weld on nuts where no one could ever reach. Funny part is needed a step stool for first time. I have shrunk since last time i pulled front apron some 23 years ago. |
#290 |
Forgot to add that the tiny "burp" holes in the thermostat allowed me to refill the radiator without running the engine. I'll be testing it next week when schedule clears.
#291 |
Well ;
I'm 6' tall and I now need a thing to stand on occasionally too ~ I usually grab an old spare 1959 Nash Metropolitan wheel & tire I have lying 'round, it's handy and worthless, no point in throwing anything I might one day use, away, amIrite ? . Too bad I didn't know you needed it, the original radiator bracing had an 'X' welded across it, usually cut off during the first clutch replacement ~ I had a nice one left over from my '49 3100 and tossed it in the scrap pile because no one here wants old Chevy parts . The 'X' was added due to flexing of the front sheet metal and cracking like you have .
#292 |
Yes the break was prolly due to missing "X" section. Ran a bolted strap to replace the broken off section. Shoulda welded it but too old to pull it and too close to radiator. Figure it will last longer than me it this point. Dying (pun) to see results of mods but have other duties to attend to for a week.
FWIW I do recall i did not have the fan running problem with the old ford fan. It was mounted high and not sure what possessed me to mount the replacement Spal where i did. Its now as high as it can get. We shall see. Thanks again. |
#293 |
Went for a short 15 mile drive today to attend a VFW meeting and sign up for Parade duty. I watched the temp very closely. Seemed to rise to 190F and just stay there. The fan did not come on at any point and think that the cool temps here (60F) and limited idling are big factors. I checked the radiator after it cooled at home and found no additional coolant was required. I think the small holes in the thermostat actually work when refilling and may even help cooling.. The NSS worked perfectly but the brake safety is somewhat hard to remember and is problematic if you need to give it some gas during starting. The real test will come towing the VFW float in the Veterans Day Parade next month - but very happy so far.
#294 |
Ok 3 days and 30 miles later its still running cool. Fan has yet to go on cause it gets nowhere near 210 anymore. While the NSS is great the brake "safety" is history. Hated it from the start. Whoever said to skip it was right -- big PITA!
In other events i happened to brush past the plug that goes into the tilt column headlight dimmer. It and the switch instantly disintegrated into little plastic crumbs. It was only 36 years old and feel cheated. Replacements were not available at any local stores so i found one on EBAY for 1/4 the price locals wanted. They had to order them anyway. What i got was an Original Borg Warner switch with picture instructions made in 1994!!!. Original box is so cool its on display in garage! Last edited by vintovka; 10-09-2022 at 06:26 PM. |
#295 |
While replacing the column dimmer switch my "life clock" reminded me that doing this stuff at my age is coming to a grinding halt very soon. That said i bit the bullet and went for all the hard as heck under dash repairs that could not wait any longer. Pulled both speedo and gauges to work on them. Had to pull headlight and starter switch's to get to them. First replaced the old dim led turn signals. These were add on custom ones between the gauges and were way too dim. New crystal green ones are very bright and came with wires attached. The wires on these are best connected with alarm style "bean" crimp connectors. Also Replaced all the crumbling wiring to the gauges including the illumination sockets, headlight indicator and converted the old turn signal indicator into a alternator light. Had to scrape off the original Green plastic lens and replace it with a red one. I rebuilt all the bulb sockets with new wires except for the alternator light one. I used an all plastic socket as it cannot be grounded. All but the Headlight and alternator bulbs were replaced with LEDs as well. Even reconfigured the vent handle for easier use. I put everything back and will save any instrument conversion for later.
As you know working under the cramped AD dash is tough on arms, back and neck. I use long thick socks with the toes cut off as arm guards to protect my 70+ year paper thin hide. It works. Tylenol and Voltaren works well for neck and body. Jack Daniels helps as well. Happy with result and may post pics soon as i recover. Hard to think this may be last time for this old man. Last edited by vintovka; 10-07-2022 at 11:40 AM. |
#296 |
Completed the alternator light install in the bottom of the speedometer and the upgraded (brighter) turn signals. Cant miss them now. Based on suggestions I wired in a way to have a "fan on" indicator and a switch to turn it on manually. Shown is the panel to hold the fan on and fan override switch. The other two lights are for any future mods i can think of.
#297 |
Nice job. Not gonna miss that signal indicator for sure. Curious, the switch panel, is it on the inside or outside of the steering column? Just wondering because I have hit my knees enough times on things placed on the dash on the outside of the column.
#298 |
Thanks. Panel is outside left of column tucked between it and the mini tach. I checked for leg clearance first and it seems well out of way.
#299 |
Looking good there .
The first generation of LED replacement bulbs were often not very bright, I too have been replacing them with newer versions that illuminate much better . I wasn't able to make an LED bulb work in the alternator's circuit, it seems an LED doesn't pass enough current to either illuminate nor excite the field windings....
#300 |
I gave up on the led alternator light and kept it regular 12 v incandescent. For some reason it still does not start charging until i rev it above 1500. Not a big problem but annoying and not sure why the regular light doesnt work as an exciter.
I am pretty close to doing all the mods/repairs that i can do so its going to a good repair guy soon. Needs minor leaks from engine, trans and diff fixed as tired of drip pans. I will add i bought a set of replacement door and ignition locks from a eBay seller. They sent the wrong ones with the 1" too long plungers. I didn't realize they were the wrong ones until i installed them. Seller has refused to answer my emails so may place transaction in CC dispute and post his name soon. Stuck with wrong parts and may have to shorten plungers myself to get them to work. Like many this may be my last use of PayPal since they say they can fine users $2500 for saying things they don't like. Might be my last EBAY buy as well as lock parts are junky. |
| Bookmarks |
