09-14-2022, 09:37 AM | #1 |
CPP ball joints/tie rod ends
I am looking at suspension/brake kits to upgrade my 63 to disc brakes in the front as well as rebuild the suspension. I like the CPP kit because it seems to have everything I need. The one kit comes with ball joints and tie rod ends made by PolyPlus. I have always used Moog suspension components on past projects and always liked them. Has anyone used the CPP parts and how do they compare to Moog. Any complaints or issues?
Thanks, Rob |
09-14-2022, 12:48 PM | #2 |
Re: CPP ball joints/tie rod ends
I can't answer your question specifically because I don't believe in the 'kit' concept.
I would place my bet that the Moog pieces are of higher quality vs what comes w/the kit. They likely get the 'kit' stuff (most likely some chain-store outfits cheap/house brand) @ a very good discount which helps them lower the overall price-tag somewhat. That's not to say what's included in the 'kit' is garbage but until I know the exact brand it's an unknown. I wouldn't use tires of an unknown origin either....
09-14-2022, 12:52 PM | #3 |
I think what you are saying about the "kits" makes sense. I tried to look up PolyPlus as a manufacture and could only find their parts in "kits" and not for buying individual pieces. Moog for instance you can go to their website and get all the part numbers and see the part. Couldn't do that with PolyPlus. That is why I was looking to see if anyone else had used them to see what they think.
09-14-2022, 09:49 PM | #4 |
Moog quality has gone downhill in the last few years. We used a set of Problem Solver ball joints on my sister's TBSS when we rebuilt the control arms and had new tires mounted, plus an alignment was done. They were loose enough to throw off the alignment and create enough of a wear pattern to kill the front tires within 30k miles. Check recent reviews, they're not what they used to be.
I've used Mevotech Supreme on a few vehicles since then and those parts seem to be holding up well.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
09-15-2022, 01:37 AM | #5 |
I don't like kits either. I usually just go on Rockauto and order parts. I know what I need usually. On my truck I used 75 year model spindles. I just had an AIM spindle snap and i put new MOOG ball joints in and I had to heat shrink both lower control arms to get them tightened up enough so they didn't move around in the hole. I have used Mevotech and they seem pretty good. They are made here in the USA in Colorado I think.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-15-2022, 09:46 AM | #6 |
That is too bad that it sounds like MOOG is not what it used to be. It has been a long time since I have used them, but again, they were considered top of the line when I had been doing this sort of thing in the past. I will check out Mevotech and see what they are about.
09-15-2022, 11:45 AM | #7 | ||
In the end, it seems nothing lasts anymore so even if the Moog isn't what it used to be, if you get the parts from a source that warranty's select items you're still likely to be better off vs. a kit purchased online (unless it's they're both from the same manufacturer).
09-22-2022, 05:40 PM | #8 |
Hello
MOOG parts are made in China. I looked for NOS MOOG parts that was on Ebay They are still out there but getting harder to find. I bought brand new Cloyes heavy duty timing chain. The box say made in USA. I do believe the box was made in USA. I think the gears are made in USA the chain made in China 😟. I trying to build my 327 with all USA made parts hard to do. A lot Cam and lifters are now made in China and they suck big time and are junk. The names of trusted parts aren’t quite what they use to be for sure. |
09-26-2022, 01:36 PM | #9 | |
--Life looks better through a curved windshield-- |
09-27-2022, 09:04 AM | #10 |
It seems like so much of it these days is hit or miss. I research and read many post on this forum, other forums, and different write ups on different brands. It seems as though some people have had good luck with MOOG and others bad. Some good with other brands and some not. Since my experience has been with MOOG, I order MOOG parts. I specifically ask for the problem solver line. I also went to my local AutoZone because I said to the guy that helped me I wanted to look in each box before I bought them because I had heard stories of MOOG mix and matching boxes. He said he understood and had heard the same thing. All my parts came in yesterday and they look ok. Problem solver on the parts. The boxes were pretty beat up. But, how many people are ordering 65 Chevy C10 parts these days. Looks like they had been on the self for a while or moved around. So, time will tell. It will be a while before I start working on the truck. Just collecting parts now. But, I am hoping all will be fine.
Thanks for the feedback and comments. Rob |
