Help with door latch
Installed new door hardware from LMC. The drivers side door, about every 5th or 6th cycle will slam like it’s hitting a brick wall and swing back open ( doesn’t latch). If reach down and manually spin the star a few times it will shut for another hand full of times. Passenger door is fine , any ideas?
Thank you |
![]() Join Date: Feb 2016
Re: Help with door latch
Sounds like a warranty issue. I would take it up with LMC and stress the safety standpoint.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Had the same phenomenon a couple of years ago. In my case the spring of the in cab doorhandle was broken, so the handle did sometimes not return and caused the same symptomes you described. It was easy to fix once I got the new part.
#4 | |
Thank you |
You have to remove the door panel to gain access to unscrew the three screws that are holding the door handle remote control in place and unhook it from the attached rod.
You'll need the whole part (about 18 bucks). The mentioned spring is located right in the middle of the part. Here is a picture: |
#6 | |
