Installing blazer fuel tank
Hello all, this question is for those that know or have done the k5 tank conversion on their c10., I have a 72 with a carburated sb 350 & mechanical pump. Currently there are no original fuel lines so i have to run new from front to back. how did you plumb it? Did you keep the charcoal canister? How did you vent it? What size fuel lines? Sorry for all the questions but I live in the city where emissions are required and want to get it right. Thank you
Re: Installing blazer fuel tank
I used 5/16" aluminum line for both supply and return lines. I ran my lines down the passenger frame rail and made my own fuel line clips. My truck is old school so there is no emissions on it so I can't answer your question on the charcoal canister.
I ran the return line as I want to go to EFT at some point down the road.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
Fuel feed line should be 3/8 for a v8
5/16 is a light fuel line size |
![]() Join Date: Aug 2009
GMC684x4 is correct , 3/8 line for supply and return , i am in the process of doing a side fill blazer tank and going to try and modifying a holley 12-308 in tank pump and regulator to use stock filler sender unit,therefore eliminating return line, have set up sniper efi on 350 with in line fuel pump mounted to passenger frame and find it to noisy , have it plumbed with 3/8 line feed and return and no issues
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD 70 Chev CST, 350 auto, PS, PB, AC, tach |
#5 | |
What is the current setup , you have a line from stock tank going to canister? The blazer tank i am using is a stock configuration tank and it has three nipples for vent , one 3/8 i am going to use for fuel filler vent, the other 2 i will use as just venting, my 70 never had the emissions crap on it
#8 | |
It’s always best to use a return line at least as big as the supply. The smaller return line CAN restrict the return flow to the tank, causing more pressure to the engine. It’s not likely with your stockish setup, but something to consider.
#10 | |
will try and take pics 68Gold/White as i go and share
#12 | |
#13 | |
Have you made any progress on this? Posted via Mobile Device |
I ran 3/8 nylon fuel line which is whats on todays cars and trucks. Doesnt corrode, easy to route, and I like the quick connect fittings that goes with it.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
#15 |
We ran 3/8 Ni-cop from pump, down frame & back to fuel filter. It's so easy to bend and work with. https://www.jegs.com/i/JEGS/555/635806K/10002/-1
Then rubber fuel hose, added protective sleeve over it, from filter looped around into tank. (That way if ever have to remove tank can drop it easily.) The vent is just rubber hose with a breather stuck on end; that was routed up into/between bedside inner & outer skin. Pic on post #18 here http://67-72chevytrucks.com/vboard/s...32#post8653432
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#16 |
Check out Hot Rod Fuel Hose online.
