72 -C10 Suprise
Afternoon Guys I worked on my Hood today removed all the paint and look at what I found under about an inch and a half of bondo a very old repair someone drilled holes and tryed to pull the dent out didn't work to well
![]() Join Date: Dec 2009
Re: 72 -C10 Suprise
Wow
![]() That is a Lot.
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
Re: 72 -C10 Suprise
Might not be the most professional way to do a repair, but I'd say it went very well if it lasted and you couldn't tell.
![]() Join Date: Dec 2013
Re: 72 -C10 Suprise
That's the way it was done before Stud guns the holes helped hold all that bondo on . drill holes along the damaged area and use a slide hammer with a screw in tip and pull away
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Re: 72 -C10 Suprise
Morning your right I've had this truck for 5 years finely I'm getting around to the body work I had no idea that was there it's all good I'm up to the challenge I'll post some pictures of the repair Thanks Saddletramp
Re: 72 -C10 Suprise
We would do it that way back in the day . Most guys would just fill but we would weld up the holes . Body filler oozing through the holes will absorb moisture and cause rust failure.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Re: 72 -C10 Suprise
The screw-in slide hammer created "outies" you couldn't flatten since the reason you were using it was no room or access for a dolly. So you couldn't pull the dent as far out, took more bondo.
I have a '68 door I thought was original paint. Now I think it had a car carrier accident when new. I stripped it bare and the area all around the standard mirror mount was filler. The paint was from '68 but not what it left the factory with
#8 | |
Re: 72 -C10 Suprise
https://youtu.be/1s4Ja1IN_Tw
![]() Join Date: Sep 2007
Re: 72 -C10 Suprise
come on down to NM i got a great hood for ya!! woth the 18 hour drive!! lol
1967custom |
Re: 72 -C10 Suprise
Morning Guys Thanks for the hood offer I've got a spare hood I like working with metal I've got a mig and tig welder I'm going to see what I can do I like the history of these trucks what the did back in the Day here's a better look of the damage Thanks
