Old 10-06-2022, 09:13 PM   #1001
67 Burb
67 Burb's Avatar
Re: 67 GMC super custom build
Originally Posted by 67 Burb View Post
Are those triangles unique to pickups or to GMC's? My Suburban doesn't have them. And I would guess the doors are original.
OOPS! I was looking at the rear corner of the door. I do have the triangle at the front corner.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 10-06-2022, 09:40 PM   #1002
chewychevy67
I've only ever had 67 and 68 trucks and they were on both of those. I can't say they would be on any other years
chewychevy67 is offline   Reply With Quote
Old 10-07-2022, 02:31 PM   #1003
chewychevy67
The skins are on with 4 tacks. Needs more alignment but ts nice to see the progress!
Old 10-07-2022, 09:44 PM   #1004
chewychevy67
I got a corvette 1969 late model to 1976 hood pin latch with spring for a hood popper. Mounts up great. Should work wonderfully. I used my original truck hood pin and not the corvette one.
Old 10-09-2022, 04:11 PM   #1005
chewychevy67
I finished both my exterior door handles for the ground switch that will iluminate the lock rings and the illuminated entry. I also started on the rad support for the headlight washer hoses and finishing up the trans cooler stuff . I need to get this stuff done for front end Mock up which will be soon!
Old 10-10-2022, 03:50 PM   #1006
chewychevy67
A few pics of the headlight washer system. The pump is on the inside of the fender. I used grommets that look exactly like the wiring grommets to keep it looking stock. The hose will run under the grill header to the other headlight on the passenger side.
Old 10-15-2022, 12:56 AM   #1007
chewychevy67
This is just loosely cut but I wanted a visual.. I might cover the woodgrain in the doors with the dash pad and seat inner pleat vinyl color as woodgrain won't work in my 67 interior. It will have a pattern close to the seats in the vinyl ad it will be horizontal as the 67 gmc's had their vinyl door panels done that way from factory. What do you think?
Old 10-15-2022, 07:49 AM   #1008
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
I like that. The 72 door panels remind me of the 65-67 corvette panels. With that insert it will tie in the 67 GMC original design. With all your period correct ideas, this truck could have been some “Big Wig” executive in General Motors COPO truck.
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 10-15-2022, 12:46 PM   #1009
chewychevy67
The inner vinyl will be the same color as the red in the seat center. It's real close to what is in there but a tad more red and matches the dash pad.
Old 10-21-2022, 06:33 PM   #1010
chewychevy67
Went and looked at the cab today. It's pretty much done as far as metal work goes. My front end will go for fitment in 2 weeks and final door adjustments. Then it will be putty work and primer!
Old 10-25-2022, 05:21 PM   #1011
chewychevy67
Today I put all the glass and guts into the doors my metal guy wants the weight in the door for final fitting. I had to move my kick panel speakers lower because of my door wiring. And I got my hood latch brace modified for the transmission cooler.
Old 10-26-2022, 10:26 PM   #1012
chewychevy67
I have a nos condenser but am toying with putting in a parallel flow condenser in a stock set up. Anyone have experience here?
Old 10-28-2022, 01:29 PM   #1013
chewychevy67
I had the lines for the transmission cooler lengthened 3.5 inches and now they reach to the inside of the rad support. They pass thu grommet directly under the ac line grommets using the same grommets .
Old 10-28-2022, 01:46 PM   #1014
CG
BlahBlahBlah
I have one of those hard bed covers too and personally dont care for the look. Id like to figure out a way to sort of trim it back so it was more flush with the besides and cover it with vinyl like a vinyl top and put some snap heads along the edges so it looks like an old school tonneau cover, but much sturdier.
Old 10-29-2022, 02:35 PM   #1015
chewychevy67
Here's the line between the rad and the cooler. I will have to wait till I get the rad support on the frame to fit the return line that goes between the cooler and the transmission. It just clears the inner fender.
Old 10-29-2022, 06:12 PM   #1016
regan wilson
regan wilson's Avatar
If it disrupts the factory body lines it doesn't belong. Just my opinion
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 10-29-2022, 06:13 PM   #1017
regan wilson
Awesome work by the way. I'm always following this thread.
Old 10-29-2022, 08:33 PM   #1018
chewychevy67
Thats awesome. Thank you. I try to show some detail of what I'm doing to help others get creative with their own ideas. I've been thru a lot of builds that have given me ideas.
Old 11-08-2022, 11:26 PM   #1019
chewychevy67
I added a headlight switch with vacuum switch on it Ana a vacuum switch from from a trans converter to the headlight washer system this way the headlights will only get washed if they are on. Save on washer fluid this way.
Old 11-09-2022, 03:18 PM   #1020
chewychevy67
I squared out all the holes on my rad support and I took 6 nuts out of another rad support ad I added them to mine where the transmission cooler mounts so it will appear stock.
Old 12-05-2022, 02:30 PM   #1021
chewychevy67
Not much happening now but I got my custom emblems mounted! I was going to drill the holes for the mirrors too but Decided to wait till I put the seat in the truck first.
Old 12-06-2022, 09:05 PM   #1022
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Here’s my red interior from my black 72. Similar to your concept with vertical strips/stitching.
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 12-06-2022, 09:37 PM   #1023
chewychevy67
Yeah that looks nice. Post a pic of the truck from the sides if you will. Looks like a nice rig.
Old 12-13-2022, 11:04 PM   #1024
chewychevy67
So as I keep looking for parts for the HD air cleaner option the more I find. All of these had a 4 inch duct coming in from the firewall to the precleaner but from there 2 bbl trucks had a 3 inch duct going to the air cleaner. Well I just found a lid on ebay for a medium duty truck with this option ant that have a 4 inch duct just to the air cleaner like the one from the cowl. So here it is. The air cleaner is like this one but I need to find a oe duct now that isn't damaged from the cowl to the precleaner. I have the other in good condition.
Old 12-27-2022, 02:02 PM   #1025
chewychevy67
With a few modifications I'm sure I could make this look like the general made if stock. I'd like to find another so both could be remote but if not I'll make the passenger mirror remote and use this other mirror to match sizes for the drivers side. .
