10-08-2022, 02:44 PM | #1 |
rear backing plates
On the 71 c10 rear I am rebuilding for my 66 c10 I'm in need of the backing plates and after a bit of searching I can't seem to locate anyone selling them new. what I did find was a guy on marketplace with a healthy collection of these trucks from 60-72. I have him looking for a good set from a 71 or 72 and my question is, would c10 trucks from 64-72 all be the same backing plates if they have the gm 12 bolt with 11" brakes? I need all the other pieces as well like the ebrake lever, self-adjuster arm, etc. and I may as well take those if in useable condition and are compatible
10-08-2022, 04:24 PM | #2 |
Who Changed This?
Re: rear backing plates
I'm pretty sure they are, but get pictures to make sure.
10-08-2022, 11:57 PM | #3 |
The 63, and I think 64, truck 12 bolts have press on backing plates. 65+ truck 12 bolts have bolt on. I believe they are the same, but I'm sure someone knows for certain.
On the brake hardware parts, get stuff from 65 at the oldest so you can have the self adjusting parts and pieces
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-09-2022, 01:16 AM | #4 | |
As for the early c10s having pressed on backing plates is just cruel engineering, thank goodness they got away from that setup. |
