Old 10-10-2022, 03:36 PM   #1
howzzzit
howzzzit's Avatar
Torque settings cab/radiator mounts
Factory manual says 35-55lbs for radiator supports. I think I see 70-90 for front cab mounts and 35-55 for back cab mounts. 20 lb spread for both. Torque to middle of the spread? 72 C10
howzzzit is offline   Reply With Quote
Old 10-10-2022, 06:02 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Torque settings cab/radiator mounts
Mock it up using the low settings until your body lines and gaps look good then torque to fine tune them , Just because your using new mounts doesn't mean it's going to drop into place , You'll be moving things around to get it nice . :chevy
Old 10-10-2022, 07:26 PM   #3
Sheepdip
Sheepdip's Avatar
Grumpy always has common sense.
Sheepdip is offline   Reply With Quote
