Old 10-13-2022, 06:13 AM   #1
nicholasmansfield
3 speed shifting issues
I have a 69 with 3 on the tree. It will shift into 3rd and 4th gear with no problem but won’t shift into reverse or 1st gear. Reverse and 1st gear work when moving the linkage by hand though. I’ve lubricated the linkage and changed the bushings so far. My next step is to try adjusting the linkage. Is there anything else I should be looking at?
nicholasmansfield is offline   Reply With Quote
Old 10-13-2022, 07:02 AM   #2
hugger6933
Re: 3 speed shifting issues
Adjust the linkage you will be amazed at the difference. There is a outline on here for that do a search.
hugger6933 is offline   Reply With Quote
Old 10-13-2022, 08:27 AM   #3
Grumpy old man
Grumpy old man's Avatar
Check and change the bushings/ sleeves before attempting to re adjust , the old bushings are probably just sloppy .
This thread may help .
http://67-72chevytrucks.com/vboard/s...d.php?t=819348
