Re: Some Cab Questions
As far as the data plate, that's going to likely be fun to try and clean up. I'd drill out the rivets and let it soak for a while (like days) in soapy water. Hopefully the paint used will soften up and you can slide it off with a fingernail. There are probably dozens of recommendations but if water doesn't work I'd start with mild paint removers like acetone... you're trying to take the silver off and leave the green. I want to kick guys in the nuts who are too lazy to take the time to mask these things off... it'd take about two minutes to mask this off.
Junior Member
![]() Join Date: Dec 2016
Thanks for all the replies.
Would you consider the tunnel pictured a "high hump" I can put the other section on and get a picture tomorrow |
#3 | |
Active Member
![]() Join Date: Jan 2021
-Pickman (Mike) 1964 C10 Fleetside LWB “George” 1963 C50 “Green Machine” 2019 Silverado 2500HD My story (Welcome Page) |
Junior Member
I've got the data plate soaking, we'll see in a couple days.
Looks like I have a bolt in low hump. Apparently a 63 item (mine is a 63). May have been a tall hump originally I'm going to drill the welds out and bolt the front section in. Any thoughts on this hole, rear of passenger floor, near the tunnel. Fuel related? |
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
![]() Join Date: Mar 2011
You can buy a replacement data plate at Classic Parts if that one doesn't strip off/
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
