Old 10-18-2022, 03:53 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Negative Battery Cable wire and Junction Block
Edited title.....
I never had the wire off the negative battery terminal, perhaps because it was a factory top post battery. I'm installing a side post battery.
I'm wondering where the negative cable's wire is supposed to be attached. Seems the fender is right, but? If the fender, my 72 is placed here, does that look right to you? Thanks
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-18-2022, 04:54 PM   #2
72SB
Re: Where does the negative battery cable wire go?
I have side post on my 72, this is where my - aux wire attaches. Basically anywhere on fender it can reach. Typically a star washer is also used
The relays are for my headlights
72SB is offline   Reply With Quote
Old 10-18-2022, 05:40 PM   #3
71CHEVYSHORTBED402
Thank you. I was wondering about a star washer or such, makes sense.
Another question please, anyone, perhaps a dumb one. Everything is new, I've yet to test with a battery. If I connect the positive cable to the mini starter I installed, but don't connect the purple wire to the starter solenoid (S terminal), does that mean I have auxiliary power without risking engine start?
Tony
Old 10-18-2022, 05:56 PM   #4
72SB
I would assume you do if you don't turn key "past" ACC mode.
You have a points dizzy or a HEI type?
leaving key on points dizzy is a problem
I assume you have the AUX + battery cable (smaller one) going to the buss terminal near RF fender
Old 10-18-2022, 06:23 PM   #5
71CHEVYSHORTBED402
It's an HEI. If you mean positive cable, yes it has a wire that connects to the junction block, apparently for the battery gauge.
Tony
Old 10-18-2022, 10:46 PM   #6
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
That wire to the junction block is the power for everything in the truck except the stater motor
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 10-18-2022, 11:58 PM   #7
71CHEVYSHORTBED402
Hmm. I thought it was strictly for battery gauge. Thank you.
Tony
Old 10-19-2022, 01:42 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Negative cable bolts to the engine block.
Old 10-19-2022, 10:29 AM   #9
72SB
the main - battery cable, yes, goes to block. The secondary - cable being discussed goes to the PS fender (pics)
+ cable the main goes to starter with the secondary going to the buss on PS fender
Old 10-19-2022, 12:27 PM   #10
pjmoreland
pjmoreland's Avatar
The assembly manual shows the negative terminal of the battery being connected only to the engine. From there, the ground connection to the cab is made through two grounding straps from the valve covers to the firewall. The cab is then connected to the frame via another grounding strap at the front right cab mount.
pjmoreland is offline   Reply With Quote
Old 10-19-2022, 01:29 PM   #11
72SB
Beyond what the trucks came with from factory, as noted above illustration, negative battery cables made with a secondary ground wire, that wire typically connect to the PS fender. While the stock - cable may not have had one, most aftermarket/replacement ones do.
Old 10-19-2022, 02:52 PM   #12
71CHEVYSHORTBED402
Good information. Per the manual my negative cable mounts on my BBC using the lower A/C compressor bracket's bolt nearest the fuel pump. It shows a washer of some sort as well, probably a ground washer. I believe it routes through the accessories handle on the front a/c bracket.
Interest PJ, Greg and I were just talking about the clips for the positive cable. I believe my Chevy had two off the oil pan, and one off the frame rail. For what worth, the clips on the frame rails vary, same their locations but close enough.
I'm still trying to understand more about the junction block. Takes three wires:
1. Red: from alternator, with fusible link. I thought this was for the battery gauge, but? Seems it serves to charge the battery, as well. Heck, I don't know.
2. Black: to cab with in-line fuse. I thought this served for the battery gauge only. What does it do?
3. Red: from positive battery terminal, for power some place and battery gauge
Tony
Old 10-19-2022, 06:13 PM   #13
'68OrangeSunshine
My bad. I did not thoroughly read the first post. I've never seen the need for a secondary tap on the Negative cable. Some pre-made cables do come with it. I just figured that was for foreign cars with a ''Positive Earth'' system.
Old 10-20-2022, 10:33 PM   #14
pjmoreland
pjmoreland's Avatar
The smaller red 3) from the battery should be connected to a fusible link that is then connected to the junction.
Old 10-21-2022, 12:00 AM   #15
71CHEVYSHORTBED402
Added, thank you, but I think that's #2
Tony
Old 10-21-2022, 12:06 AM   #16
pjmoreland
pjmoreland's Avatar
#2 is the 12awg wire that is part of the harness that runs over the radiator to the alternator and fuse panel, right? The fusible link is not in that wire.
Old 10-21-2022, 12:38 PM   #17
71CHEVYSHORTBED402
Perhaps some variances? I'm holding the wire off the positive cable, it's just a wire.
Tony
Old 10-21-2022, 12:44 PM   #18
pjmoreland
pjmoreland's Avatar
That's interesting. I've never seen a fusible link like that. Mine looks like a regular wire and is spliced onto the wire coming from the battery terminal. Is your headlight harness a factory original?
Old 10-21-2022, 12:54 PM   #19
Louisvillekytruck
Great information
Louisvillekytruck is online now   Reply With Quote
Old 10-21-2022, 01:03 PM   #20
pjmoreland
pjmoreland's Avatar
The information in the assembly manual doesn't always match up with reality, but here are a couple pages that show the location of the fusible link. There's a note on there that says, "FUSIBLE LINK (PART OF BATTERY POSITIVE CABLE ASM)." The schematic shows it that way as well.
Old 10-21-2022, 01:04 PM   #21
68 P.O.S.
Hmm, interesting. On my 72, the auxiliary negative wire is routed to the core support. It attaches to the same bolt the headlight negative wire uses.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 10-22-2022, 03:46 PM   #22
71CHEVYSHORTBED402
I have a replacement front lights harness,, but my old one has the fused link in the harness as well.
I wondered about mounting the negative cable,s ground wire with the headlight ground. I'm not near the truck, if I recall the headlight ground is a 5/16 screw, seems the battery wire,s terminal takes a 1/4 .
Tony
Old 10-22-2022, 06:32 PM   #23
garyd1961
I know it's not factory but I connect my ground to the engine block and add a second ground from the engine block to the frame. You can't have too many grounds on these old trucks.
garyd1961 is offline   Reply With Quote
Old 10-23-2022, 12:10 AM   #24
mr48chev
mr48chev's Avatar
Factory originals look pretty much like a length of regular wire that usually has shrink tube at each end. A lot of the aftermarket fusible links look like the one he showed.
My ongoing truck projects:
Old 10-23-2022, 12:42 AM   #25
mr48chev
mr48chev's Avatar
Your secondary ground wire off the battery cable just goes to a spot on the body where you are comfortable with putting it. It serves as a more direct ground to the battery for the lights and for other accessories.
The purple wire has to go to the S post of which ever solenoid you are going to use to energize the starter. Without it properly connected the solenoid isn't going to function and you won't be able to crank the engine.
You don't need the resistor bypass wire from the R post on the solenoid with HEI.
When I changed my 71 to HEI I ran the wire for the hei from one of the hot when the key is on pins on the Fuse block so I could run a heavier gauge wire to the hei.
Make sure that you have the correct HEI wire terminal to plug into the HEI rather than just use a female slide. A female slide will slide at an inopportune time if it loosens up just a tad. Been there done that.
