Old 10-23-2022, 12:05 AM   #1
mr48chev
mr48chev's Avatar
Re: Bearing cap eroding?
Make sure that someone didn't trim the cotter key wrong and that it wasn't rubbing in the cap.
Still inspecting and repacking the wheel bearings is just periodic maintenance and if you do it in far less miles than you planned it is just an hour of your time and a little bit of wheel bearing grease.
I'd pull the bearings out, wipe them off with a shop towel and inspect them and properly pack them and reinstall them. Absolutely do not wash them with solvent unless you fully intend to replace them. The solvent never gets out of the bearing and won't allow the grease to stick to the bearing surfaces right. I was taught that 60 years ago as an automechanics student in high school and have followed it and do not have wheel bearing trouble that doesn't have a different cause. In all the years I was doing brakes for a living I never had a car come back with bad wheel bearing after I serviced the bearings.
My ongoing truck projects:
Old 10-23-2022, 09:39 AM   #2
72c20customcamper
72c20customcamper's Avatar
Never heard that said about cleaning bearings .
In 50 plus years never had a problem cleaning bearings in lacquer thinner let them dry and repack .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-23-2022, 12:59 PM   #3
kwmech
I have heard of it...if you leave the solvent. I actually use K1 kerosene in my solvent tank and I'll wash them out if needed for inspection. If they are smooth and free of foreign material, I'll rinse them with some brake clean or thinner and repack. Never had a problem
Old 10-23-2022, 11:40 AM   #4
jabborabbo
jabborabbo's Avatar
This makes perfect sense based on my original info regarding the location of the shavings, the present condition of the bearings, PLUS the fact that the cap was somehow teased off the axle!
I’ve already bought replacement bearings just in case, and I did wash the old ones in solvent to inspect them.
Thank you Sir!!!!
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
