Old 10-24-2022, 09:21 PM   #1
44SAA
Bleeder Valve 1980 C20
After some Kroil, vice grips and bloody knuckles I cracked all 4 valves loose for the first time in 42yrs. In the process I buggered up the hexes. Figure might as well replace all 4 valves now. Question- Anyone know the proper thread size? Seeing lots of conflicting info. Last thing I want is to cross thread…thanks
44SAA is offline   Reply With Quote
Old 10-25-2022, 08:54 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Bleeder Valve 1980 C20
As cheap as they are, I would just replace the whole wheel cylinder and calipers
...after all ,theyve got age on them..
But..you can just crimp the rubber brake hose with some vice grips, to prevent all the fluid from draining, remove the bleeder, take it with you to the parts store..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-25-2022, 12:06 PM   #3
Dead Parrot
At least on the rears, cheap enough to buy 2 new cylinder assemblies then use the new correct bleeder screws on your old ones until you feel like tackling replacing the old ones. Then just transfer the new screws back to the new cylinders.
Dead Parrot is offline   Reply With Quote
Old 10-25-2022, 01:11 PM   #4
44SAA
If you have a 1980 C20, front bleeder screws are M10-1.5 X 30mm.
Old 10-30-2022, 09:56 AM   #5
Pontiac1976
Pontiac1976's Avatar
I all was thought that help the rubber hoses break down to clapping hoses faster. I did my self, but I stopped started to use (screw bolts combo or plastic plugs anything that fits that does not strip hole needing plugged Because you still should bleed the brakes any time you open any line or fitting or big adjustment to the brakes.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
