Old 10-24-2022, 09:28 AM   #1
72Mountaineer
72Mountaineer's Avatar
Different parking brake
Due to the install of a modern (88 S10) tilt steering column, my stock 64 parking brake doesn't fit. The kind that mounts in front of the driver's kick panel that has the lever to disengage the brake seems like a good option, although the cable may be a problem as it will be on the outside of the frame. Anybody done this?
72Mountaineer is offline   Reply With Quote
Old 10-24-2022, 01:23 PM   #2
TxCajun
TxCajun's Avatar
Re: Different parking brake
Forum search turned up these:
http://67-72chevytrucks.com/vboard/s...=parking+brake
Wampus Cat Build: http://67-72chevytrucks.com/vboard/s...d.php?t=759550
TxCajun is offline   Reply With Quote
Old 10-25-2022, 10:29 PM   #3
The Sub
The Sub's Avatar
I put a pedal one on my 65 that I got from the local junk yard. http://67-72chevytrucks.com/vboard/a...1&d=1666751279
Jim
The Sub is offline   Reply With Quote
