Old 08-16-2018, 10:58 PM   #1
rsgt
rsgt's Avatar
AC blower motor wheel project
I have been thinking about doing this for awhile. I wanted to see if could get the AC to blow hard like a late model. After some research I found a late model blower wheel that was the right size. I had to buy blower motor with the wheel just to get the wheel. I got it on ebay for $33.00 it is for a 07-11 jeep liberty. The wheel has 41 fins on it and my 72 AC wheel has 29 fins. The fins on the newer one are also much larger. This took me a few hours to put together. The new wheel would require a much longer shaft that my motor has so I cut the center out and I clipped and cleaned up an old chevy blower wheel and epoxied and rivet them together. The fit was so good they self centered themselves. I had to open up the blower housing hole about a 32d all the way around to get the wheel in. Also took some side cutters and clipped the top of the fins at an angle for clearance. This runs smooth and quiet and blows hard. I think on medium it blows about what it used to on high.
rsgt is offline   Reply With Quote
Old 08-16-2018, 11:26 PM   #2
dmjlambert
dmjlambert's Avatar
Re: AC blower motor wheel project
Now that is a good project. Thanks for that info and pictures.
dmjlambert is online now   Reply With Quote
Old 08-17-2018, 12:03 PM   #3
bill3rail
bill3rail's Avatar
Classic Chevy Truck Inventions.
You should be given the Ingenuity Award for the year.
P.S. what is the difference in the heater only wheel, this may help us non-AC guys too.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 08-17-2018, 12:28 PM   #4
truckster
truckster's Avatar
Thanks! I'm sure that will be one of my future mods.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 08-17-2018, 08:38 PM   #5
rsgt
rsgt's Avatar
Bill, I do not know about the heater only wheel. I am sure someone here does.
Old 08-19-2018, 06:22 PM   #6
rsgt
rsgt's Avatar
A short video trying to show how it blows out the center vent. https://youtu.be/hcRlWh4QmM8
Old 08-19-2018, 07:40 PM   #7
Red71gmc
It's saying the video is unavailable when I try. However your mod is on my list of things to do.
Red71gmc is offline   Reply With Quote
Old 08-19-2018, 08:15 PM   #8
rsgt
rsgt's Avatar
Ok I will try to work on the video. Thanks
Old 08-19-2018, 08:38 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
It's not just a Red71gmc problem....I couldn't see the video either. Looks like a very good mod, thanks for posting!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 08-19-2018, 09:24 PM   #10
Red71gmc
I looked through your driver build rsgt. Your a resourceful guy. My truck originally was the same colors and I wish the PO would have repainted it those colors. It just looks good on these trucks. Especially with the rally rims. Good job.
Old 08-19-2018, 09:29 PM   #11
Red71gmc
Your video worked this time. I will be doing this. It looks like it could be used for a hair dryer if I just still had hair.
Old 08-20-2018, 06:12 AM   #12
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: AC blower motor wheel project
That looks like it's pretty strong. I wonder if it would work on a 64 SS Impala as well.
rsgt,
Here is your link.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-20-2018, 08:54 AM   #13
rsgt
rsgt's Avatar
rsgt,
Here is your link.
www.youtube.com/watch?v=hcRlWh4QmM8
Andy, It might work, The wheel is 2 3/4 inches by 5 3/4 inches.
Old 08-20-2018, 09:00 AM   #14
rsgt
rsgt's Avatar
Here are a couple more pictures. I put a heavy weight on the wheel when I glued them together, Then when it was cured I put the rivets in. I put a weather strip seal around the edge of the motor plate before I put it back on the truck.
Old 08-20-2018, 09:36 AM   #15
rsgt
rsgt's Avatar
rsgt,
Here is your link.
Andy, What you have to watch for is depending on the car, The wheels come in clockwise and counterclockwise.
Old 08-20-2018, 10:51 AM   #16
Andy4639
Old member
Andy4639's Avatar
Talking Re: AC blower motor wheel project
Thanks, the truck does pretty good as is but my 64 SS on high is like slow speed in my 71 C 10.
Old 10-26-2022, 03:04 PM   #17
Thealien
Thealien's Avatar
Tagging so I can find it later. Nice mod!
Old 10-26-2022, 09:59 PM   #18
truckster
truckster's Avatar
I did your mod on mine when it put it together a year and a half ago. It works great.
Old 10-27-2022, 06:28 AM   #19
jjzepplin
jjzepplin's Avatar
Where do you guys find the time to do this? On my list now twice!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-27-2022, 12:30 PM   #20
MARKDTN
Can't speak for trucks but the hot tip for C3 (68-82) Corvette blower motors was to use C4 (84-96) Corvette blower motors and add a 3/4" spacer. Not sure if they had more blades but they were at a different pitch and the cage was longer. It supposedly worked well although I never did one.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 10-28-2022, 10:13 AM   #21
Myself
Also, posting just so I can find it later.
Myself is offline   Reply With Quote
