Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 08-04-2004, 03:00 AM   #1
dapolice1
We can roll all Day!!
WTB 1 Ton Brake Stuff 1984
Guys I pulled a blowen 6.2 and installed a 454. I have a regular power steering pump for the 454 but the truck originaly came with Hydro boost. I would LIKE to convert to a vacume booster but heard the 1 tons do not stop well with the vacume booster.
So, I either need the 1 ton vacume booster, or the proper hydroboost powersteering pumb and braket for the 454.
ANYONE??
dapolice1 is offline   Reply With Quote
Old 08-04-2004, 10:32 PM   #2
aesj2
Stay with the hydroboost. The pump should work on the 454 but you may need to change the brackets.
aesj2 is offline   Reply With Quote
Old 08-05-2004, 09:08 PM   #3
BigBlockBurris
BigBlockBurris's Avatar
Booster vs. Hydroboost
Man, Stay with the hydroboost. Mine was leaking, so I swapped it out with a 1 ton booster. Big Mistake. My truck will not stop for nothing! I am going to switch back as soon as I find a good one! As far as the lines go, use your regular pump, just put a "tee" in the low pressure line to make the third line needed in the hydroboost. I have done several diesel to gas trucks this way and not a single problem yet and they STOP! E-mail me if you have anymore ?????'s. Later
BBB
BigBlockBurris is offline   Reply With Quote
