Old 10-27-2022, 11:44 AM   #1
cj847
cj847's Avatar
Special tools
As I am getting older, weaker, and hopefully wiser, I find myself looking for tips, tricks, and tools to make the job easier. The purpose of this thread is for a log of innovative, homemade or store-bought tools to save my back. To start I am looking for an easy way to put wheels on my truck. I struggle to lift a wheel/tire combo up 2" while lining up the lugs. I've used levers, pipes etc to get by. But, I think someone out there is smarter than me and has an easy way. Please post up anything you have for this problem as well as other helpful tools. If this is duplicating a prior thread please post a link. Thanks.
cj847 is offline   Reply With Quote
Old 10-27-2022, 12:02 PM   #2
LNP
Re: Special tools
I use to work for Goodyear for over 22yrs I feel your pain. Heavy ones I did on the ground I used a long pry bar to lift the tire/wheel up so I could start it on the lugs. Another easier way if you can get the vehicle high enough is to use a motorcycle jack. That works real well. I use it here at my PC shop to raise heavy 4x4 wheels/tires up to get them on the balancer.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 10-27-2022, 12:05 PM   #3
72SB
Re: Special tools
Well for me I use what you already have, my legs. I just sit and put tire across my upper legs and just lift tire up to wheel studs and rotate if needed to get over studs. I first set the tire with the holes close to orientation they need to be so minimal roll left or right to line up with studs. Basically, let legs do the lifting, not back or arms
While I have not seen one, you could make a curved cradle that goes on a floor jack to support tire but obviously you still need to lift the tire onto that cradle, balance guide it with one hand while you jockey floor jack into place
72SB is offline   Reply With Quote
Old 10-27-2022, 12:41 PM   #4
geezer#99
geezer#99's Avatar
Re: Special tools
I had a set of car Dollie’s like in this link. I modded one to fit a small bottle jack on one end in the middle and could lift one side enough to lever the tire high enough.
They do make ones now that have a hydraulic ram attached.
A bit pricey though.
https://www.summitracing.com/parts/mrm-m998035
Old 10-27-2022, 04:59 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Special tools
Make a rectangular frame out of 2" X 2" lumber, 4 feet long and 1 foot wide. Put it together with screws. You should be able to roll the tires onto the wood. The end you're going to lift should be attached above the long pieces so that you have a handle. You should have plenty of leverage that way. I knew a guy who weighed all of 140 soaking wet who worked on big trucks. He used something similar, but greased the wood. I personally don't want grease on my tire treads, so I just use that assembly as a pry bar. I have the arm strength, but an arthritic back is my problem.
~Steven
Simi Valley, CA
Old 10-27-2022, 05:42 PM   #6
72afr
Beep! Beep!
72afr's Avatar
Re: Special tools
This is how I was taught to do it as well. Works well enough for my oversized truck/jeep tires.
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport
2003 Chevrolet 2500HD CC 6.0 4wd
2004 Jeep Rubicon some aftermarket stuff...
2019 Jeep Unlimited Rubicon (the wife's baby hauler)
72afr is offline   Reply With Quote
Old 10-27-2022, 06:57 PM   #7
FamilyTruckster65
Re: Special tools
https://www.amazon.com/Aain-DY016-He...3D&sr=8-4&th=1
how about this?
FamilyTruckster65 is offline   Reply With Quote
Old 10-27-2022, 07:17 PM   #8
72c20customcamper
72c20customcamper's Avatar
Re: Special tools
Motorcycle jack . I’ve used it to install tires on my dodge 315/70-17 34.5 inches tall and it works well as a transmission jack .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-27-2022, 07:33 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Special tools
Originally Posted by FamilyTruckster65 View Post
That looks great! More than I'd like to spend, but compared to a sore back for a few days, it might be worth the cost.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-27-2022, 07:46 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Special tools
Sore back, indeed. I pulled the PG trans out of my '65 Malibu and put in a 350 trans, with no jack. Just John Armstrong. The older I get, the better I was. I wouldn't even try to pick that trans up off the ground, let alone bench press it into place, these days. It's probably why my body is so trashed...
~Steven
Simi Valley, CA
Old 10-27-2022, 07:55 PM   #11
jumpsoffrock
Re: Special tools
I spent a lotta years listening to a lot of my friends telling these stories. We're only in our 30's and a lot of them are all broken. Some of them are on prescription pain pills, hey sound like they're 80.
They went through all that pain just to be tough.
jumpsoffrock is offline   Reply With Quote
Old 10-27-2022, 09:17 PM   #12
Getter-Done
Getter-Done's Avatar
Re: Special tools
Maybe something like This?
Link: https://www.northerntool.com/shop/to...ba19dc319da71d
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 10-27-2022, 09:48 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Special tools
I wasn't trying to be tough, I just didn't have a lot of help around. I truly hope that the younger guys around here aren't as cash-strapped as I was back in the day, and have more local friends to help. I was one independent cuss back then, and that attitude has come home to roost on my body. I'm only 70, and I avoid pain pills like the trouble they are. Doctors are telling me I shouldn't even take NSAIDS because of my failing kidneys, just Tylenol, which isn't all that great, for me, so I take nothing, if I can help it. The list just goes on. Eh, life happens.
~Steven
Simi Valley, CA
Old 10-29-2022, 01:03 AM   #14
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: Special tools
I got this years ago, works great on all sizes of tire & wheel combos. It was real handy when I put the 19.5s on my K/30. The outside drive tire & wheels weigh 120 pounds each and the inside duals we're even heavier. I could lift the tire with one hand and easily turn it to match up lugs with the other hand. I don't use it often but I wouldn't be without, it's a back saver!
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 10-29-2022, 02:16 PM   #15
CG
BlahBlahBlah
Re: Special tools
Old 10-29-2022, 05:21 PM   #16
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Special tools
Originally Posted by CG View Post
I used to do that with 4-cylinder engines in Chevy Vegas. Just the short block. Pick it up, sit on a fender and swing over, plop the engine into place. SBC short blocks off the ground, into the bed of a truck, alone. Yup, I'm paying for it.
~Steven
Simi Valley, CA
Old 10-31-2022, 09:35 AM   #17
Re: Special tools
I do the tires with my legs under as well. I have a starter bolt broken off in the block (recessed) and I'm dreading taking care of it. I wish I had a lift. It's a long reach up under the '72 K2500. I considered pulling the engine so I can put it on a stand and roll it over. A lot of work, but I could re-gasket and reseal engine/trans/transfer case. I see less pain in all that than reaching up under the truck. What I'm thinking to try first is pulling tires to lower or jack it up enough to sit upright under it. Working position is a big factor for me. I know what works and what hurts
I wasn't trying to be tough when I lowered the NP205 in a '71 K/20 onto myself then rolled over to ground, then do the 4spd the same way on gravel to replace the clutch. It was January, I had just bought a house Dec 29, had snow plowing contracts, and a siding business running to feed my family. I was just doing what I had to do using what I had and money wasn't one of them. In fact, I couldn't buy a clutch so I pulled the TH350/NP205 and required parts from my '71 Blazer and put that in. I borrowed a floor jack to install. I somehow didn't injure myself.
Old 10-31-2022, 10:03 AM   #18
jumpsoffrock
Re: Special tools
With a new house and commitments, you were in a tight spot in more ways than one. Necessity is the mother of invention.
Old 10-31-2022, 10:25 AM   #19
skinnan
Re: Special tools
In these situations I end up placing my foot near the spot the tire needs to be lifted from and roll the tire up on my foot. That usually gives my the few inches I need to get it up on the lugs.
skinnan is offline   Reply With Quote
Old 10-31-2022, 11:04 AM   #20
RichardJ
Re: Special tools
Have any leaf springs laying around? I have a leaf out of a set that is about 18" long and has a nice curve on it. Slide one end of it under the first rib or two of the tire tread and push down on the other end.
Easy Peasy. They even have a hole in them to hang on the wall and is ready to use as a pry bar for anything else. I have two different lengths hanging on the wall that have been used for hundreds of different things.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 10-31-2022, 11:11 AM   #21
Re: Special tools
The best tool for a bad back is a lift.
I want one. Never knew about these.
Yeah, that was my song. Freezing pipes added their own special flair. Or was that flare? Of all things, that was a record breaking winter for cold and snow also. I don't think I was barefoot, she wasn't pregnant, and my dog was just a healthy puppy
Old 10-31-2022, 01:27 PM   #22
mrein3
mrein3's Avatar
Re: Special tools
It took me a while but I finally found the post I was looking for. I originally posted this on 5 January 2008. These aren't tools to save your back - except for maybe the distributor wrench - and all the operations these tools perform I have done with other tools and/or means, but when you get the right tool there is no going back.
1. Distributor wrench says snap-on and came from a used tool store that no longer exists. The used price was $15. The online catalog price for new was $48.50 in 2008. Now I see it online for $81.25.
2. Brake bleeder wrench.
3. GM door handle/window crank spring clip remover.
Link to original post:
https://67-72chevytrucks.com/vboard/...d.php?t=272608
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-31-2022, 02:20 PM   #23
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Special tools
Yup, I have those, too! I have a manual valve spring tool that I bought to put valve stem seals on my '64 Malibu way back in the early '70s
~Steven
Simi Valley, CA
Old 10-31-2022, 05:03 PM   #24
RichardJ
Re: Special tools
Over the counter tools are nice, but the OP was looking for home made tools as well.
I still use the old style beam torque wrench's, but mine is limited to 100 lb/ft.
A length of channel iron that effectively increases the "lever length" can increase the range of the torque wrench. In my case, I doubled the "lever length" and doubled the range to 200 lb/ft. It was easy to bolt a breaker bar to the channel iron and cut a square hole for the torque wrench. I just have to remember not to use that piece of channel iron for some other purpose.
Old 10-31-2022, 05:17 PM   #25
RichardJ
Re: Special tools
I do have one store bought tool that I never use, but when I do, its worth ten times what I paid for it. The short arm on the left has fittings to latch into most door latches, but if you remove that arm you can roll the door in to be completely flush with the body.
One-man door installer with no fuss. HF hasn't sold it in years. Much of what they sell is junk, but this thing is golden.
