Old 10-31-2022, 12:56 PM   #1
Johnl48
Adding a neutral safety switch
I converted to an automatic from a 4 sp. I'm using the original harness, so I know I have to reroute the reverse light plug into the cab but what do I need to do to add a wire for the neutral safety switch ?
Thank
Old 10-31-2022, 02:30 PM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Adding a neutral safety switch
Neutral Safety switch (NSS) power comes from the ignition switch. If you had a manual with no switch, you will need to run the purple wire from the ignition switch to the NSS, then from the NSS to the starter. Doesn't have to be purple if you're the only one who works on it, because you will know. But I'd run it all purple in case someone else is driving it and you aren't available to fix it.
~Steven
Simi Valley, CA
Old 10-31-2022, 02:37 PM   #3
damnyankee36
damnyankee36's Avatar
I've never owned a manual trans truck so I'm assuming there was no clutch pedal-mounted safety switch. Find a good spot to cut the purple wire under the dash that goes from the ignition switch to the starter solenoid. Route and/or extend the ends to the backup lights/neutral safety switch on the column and connect them there.
Again, I am assuming that you will also be using an auto column to mount the switch. I guess all manual trucks didn't have any switch mounted on the column?
damnyankee36 is offline   Reply With Quote
Old 10-31-2022, 03:11 PM   #4
Johnl48
So this wire gets cut and attached to the switch ?
Old 10-31-2022, 04:06 PM   #5
Thealien
Thealien's Avatar
On my 1972 blazer that is a factory four-speed vehicle the two purple wires in the harness come out about the same place they would on an automatic. There’s a small plug plugged into it with a purple wire looped back to itself. So in order to connect it to an automatic neutral safety switch I would just have to unplug the loop and plug the connector into the neutral safety switch on the column.
Old 10-31-2022, 04:30 PM   #6
Thealien
Thealien's Avatar
I want to add that this picture is from an M and H replacement harness. I can’t imagine they would make completely different harnesses for automatics and manual transmissions.
This is a picture of the connector I mentioned in my post above. I have it on top of the steering column so it doesn’t get damaged with the break or clutch pedal since it is not attached to a switch. I’m not 100% sure if the factory did it exactly like this or if they buried that connector in the harness?
Old 10-31-2022, 05:46 PM   #7
Steeveedee
Steeveedee's Avatar
Yup, that purple one.
~Steven
Simi Valley, CA
Old 10-31-2022, 07:56 PM   #8
Johnl48
Mine doesn't have that plug
Old 10-31-2022, 08:53 PM   #9
Thealien
Thealien's Avatar
Follow the wire from the ignition switch it exits the cab at the bulkhead connector. It would probably be easier to cut it down there if you are sure that connector isn’t buried somewhere.
Old 10-31-2022, 09:50 PM   #10
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Same and agree.
Some notes I took that may be helpful. Gauges are sometimes a guess. Heck even color, I'm color blind but did some research, mostly
The brake light switch wires are one 18 AWG white wire to the turn signal switch, and one 18 AWG orange wire from the fuse box. The harness runs from the RH side of the fuse box and wraps with the neutral safety/reverse switch harnesses.
The neutral safety/reverse lamps switch harnesses run from the RH side of the fuse box and plug into the switch as:
• The plug with two 12 AWG purple wires connects to the switch’s RH terminals for neutral safety.
• The plug with two 18 AWG light green and two 18 AWG dark green wires connects to the switch’s LH terminals for reverse lamps, with the light green wires positioned on top.
The wires are taped together with the brake lights switch wires, and there’s an in-harness clip that plugs into the firewall adjacent where the fuse panel reads CLSTR. FEED.
Corrections welcome
Some really good threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=592968
http://67-72chevytrucks.com/vboard/s...d.php?t=801374
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-31-2022, 11:54 PM   #11
pjmoreland
pjmoreland's Avatar
You could pop the purple wire out of the bulkhead connector on the firewall and plug it into the Neutral safety switch. You could then get some more purple 12 gauge wire and a couple of Packard 56 crimp terminals and make a short wire to run from the other terminal on the Neutral safety switch to the bulkhead. This approach saves you from having to extend or splice any wires. You need to use the two NSS terminals that are parallel and close together. I believe this is the correct connector housing.
https://jcaparts.com/collections/bui...ator-pin-black
These are the crimp terminals (select 12 gauge for purple wires and 18 gauge for green wires).
https://jcaparts.com/collections/che...-awg-18-20-awg
This should be the reverse light connector housing in case you want to tackle that issue as well. I believe you would pop the light and dark green wires out of the bulkhead, pop them into this housing, and plug it into the NSS.
https://jcaparts.com/collections/che...-housing-black
pjmoreland is offline   Reply With Quote
Old 11-01-2022, 06:51 AM   #12
Johnl48
Originally Posted by pjmoreland View Post
You could pop the purple wire out of the bulkhead connector on the firewall and plug it into the Neutral safety switch. You could then get some more purple 12 gauge wire and a couple of Packard 56 crimp terminals and make a short wire to run from the other terminal on the Neutral safety switch to the bulkhead. You need to use the two NSS terminals that are parallel and close together. I believe this is the correct connector housing.
These are the crimp terminals.
This should be the reverse light connector housing in case you want to tackle that issue as well. I believe you would pop the light and dark green wires out of the bulkhead connector, pop them into this housing, and plug it into the NSS.
Your links don't work
Old 11-01-2022, 10:50 AM   #13
pjmoreland
pjmoreland's Avatar
I fixed them
