Old 10-26-2022, 07:21 PM   #1
Johnl48
Kick panel vents with a/c ?
I converted a non A/C cab to an A/C one. Purchased a factory system from someone. What happens to the kick panel vents on an A/C truck ? Do they get sealed ? I noticed there is a vacuum actuator under the unit near the kick panel vent
Old 10-26-2022, 08:38 PM   #2
chewychevy67
Re: Kick panel vents with a/c ?
My 67 still has the pull handle on the driver side and vent operates just as a non ac truck.
chewychevy67 is offline   Reply With Quote
Old 10-26-2022, 08:40 PM   #3
Johnl48
So no handle on pass. Side ? That's attached to actuator ?
Old 10-26-2022, 09:10 PM   #4
4x4 k1500
The right kick panel vent is activated to use as a vent when the ac control is set on recirc. Vac is used to open the vent when the air cond has all 3 levers set to the very left side of the control, vac also closes the cowl inlet it the same time
4x4 k1500 is offline   Reply With Quote
Old 10-26-2022, 09:12 PM   #5
Johnl48
Thank you
Old 10-27-2022, 04:38 PM   #6
LNP
I converted my turck to AC. I just removed my handles and sealed the doors shut. I have been workin on an idea to use the right side vent as a fresh air duck for heating in the cold so the windows wont fog up when using floor heat.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 11-01-2022, 06:49 PM   #7
tdangle
tdangle's Avatar
My 70 driver side is a manual vent, passenger side is controlled by A/C vacuum pot.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 11-01-2022, 07:00 PM   #8
LNP
It has a duct over it doesnt it? You have a photo of it by chance?
Harley
Old 11-01-2022, 10:02 PM   #9
SRU1436
Can you run the AC while you have the heat on, this would eliminate the fog/condensation inside the cab? That’s what I do in all my vehicles (none c10 vehicles)
SRU1436 is offline   Reply With Quote
Old 11-01-2022, 11:00 PM   #10
FirstOwner69
FirstOwner69's Avatar
First picture is driver side. Second is passenger side. Third is the cowl vent mentioned in post 4. My '69.
Jim
FirstOwner69 is offline   Reply With Quote
Old 11-02-2022, 09:30 AM   #11
LNP
No the way the Classic Air system works is the ac is only on when in defrost mode. Thanks
Harley
Old 11-02-2022, 09:32 AM   #12
LNP
Thanks this gives me some things to think about.
Harley
Old 11-02-2022, 03:34 PM   #13
68 C10 Driver
My A/C is always in 'recirculate mode'.
68 C10 Driver is offline   Reply With Quote
Old 11-02-2022, 03:40 PM   #14
LNP
Harley
