Old 11-03-2022, 04:36 PM   #1
Factory Guy
Factory Guy's Avatar
Intake Plug & GLUE?
Does this plug Glue to the top of this intake hole?
Mine came off when I tore my LS engine down? Suggestions on what to use for glues? RTV?
Factory Guy is offline   Reply With Quote
Old 11-03-2022, 07:08 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: Intake Plug & GLUE?
it was most likely plastic welded from factory and is now broken.
1) maybe clean the bejesus out of it, skuff it up with course sand paper and use a high quality plastic adhesive glue.... what goes there... brake booster is on the back of the intake correct?
2) replace intake
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 11-03-2022, 11:25 PM   #3
ls1nova71
ls1nova71's Avatar
I have a spare intake I'd let go for cheap if you want to replace it. Just let me know.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-04-2022, 12:55 AM   #4
kglowacky
JB Weld
kglowacky is offline   Reply With Quote
Old 11-04-2022, 07:44 AM   #5
Joyridin
Find a plug and use a soldering iron to melt it back in place. I have done this many times with no issues. Depending on the size, you could even thread it for a pipe plug and screw in a plug. This is an easy fix.
Joyridin is offline   Reply With Quote
Old 11-04-2022, 12:04 PM   #6
Factory Guy
Thanks guys!
I was thinking JB weld, but I like the soldering iron way, better. Will give that a try!
Old 11-04-2022, 12:05 PM   #7
Factory Guy
2) replace intake
On mine the PCV valve connected there, and yes the brake booster came off the back of the intake.
Old 11-04-2022, 12:06 PM   #8
Factory Guy
Thanks, going to try and plastic weld it with the old soldering iron first.
