Old 08-05-2004, 02:00 PM   #1
71400lb
71400lb
What's the widest tire I can put on 71 3/4?
I know the tires on there now are 16 incher's, but I think they're 85 series. I'd like to put wider tires on the truck and was wondering what's the widest tire I can put on those stock rims?
Truck is a 1971 Cheyenne C/20 2 wd long bed.
Thanks,
Rick
71400lb is offline   Reply With Quote
Old 08-05-2004, 02:47 PM   #2
71400lb
71400lb
8 lugs!
Old 08-06-2004, 09:11 AM   #3
71400lb
71400lb
Maybe I worded this wrong...the tires that are on the truck are 215/85/r16's on the original 8 lug rims...I don't know how wide these rims are, and was wondering if anybody knew...then I could ask the tire place what's the widest tire that can be put on those rims. I think the skinny tires make the truck look a little "whimpy".
Rick
Old 08-06-2004, 11:13 AM   #4
sactoC10
71 DELUX
sactoC10's Avatar
Go to 1010tires.com, scroll down about 7-8 links on the LHS and open up the "tire size calculator".
This is a great tool. You can find out what tire size will fit what rim, width, diameter, radius, compare sizes...and then when you are getting close to what you want, you can even click on that tire size and get a list of some brands available, with rating information.
Personally, I have no idea how wide your rims are. I have 295/50/15's on my lowered LWB... 15x10" wheels. As you can see, still have plenty of room!
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50
2003 FORD Escape
1998 Honda VTR1000
sactoC10 is offline   Reply With Quote
Old 08-07-2004, 08:49 AM   #5
71400lb
71400lb
Thanks Sactoc10,
that website is helpful. Looks like the stock width of thos rims are 6 inches.
Appreciate it,
Rick
Old 08-07-2004, 12:06 PM   #6
ryan68
Certified Chevy Man
ryan68's Avatar
They are 6" or 6.5" wide I think. You can put a 265/75/16 on them, about 31.6" tall. They should clear no problem and give you some meat. Only part to look out for in terms of rubbing is the inside back wheel wells. The 265's are right 2" wider than your tires now, so an 1" and an 1" out from where they are now. Overall Diameter will be less than 1" taller.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
