Old 11-09-2022, 11:25 AM   #1
44SAA
Coolant Drain Plug
Howdy- is the nut shown above the “2” and 12 o’clock from “S” the coolant drain plug?” Thank you
44SAA is offline   Reply With Quote
Old 11-09-2022, 11:57 AM   #2
kwmech
Re: Coolant Drain Plug
YES it is. Use a 6 point socket as it will be very tight. When it comes out, more than likely it will not drain due to sediment and a crusty like gunk. You may have to shove a small screw driver up in the hole and wiggle it around to get it moving. Always nice to have an arm and elbow full of coolant
Old 11-09-2022, 12:07 PM   #3
44SAA
Thanks KW- if I’m not bleeding or covered in fluid, something miraculous occurred. Shoving a water hose down the thermostat hole help bust up crud?
Old 11-09-2022, 01:12 PM   #4
Dead Parrot
It is A coolant drain plug. There should be a matching one on the other side if you have a V8. You need to remove both to drain all the old stuff out.
Better idea for moving crud out is forcing a cut garden hose over one of the heater hose nipples on the intake. Good use for a dead garden hose. Leave the t-stat and housing in place and let stuff come out the radiator opening.
When finished with the flush, re-drain and fill with either 50/50 or pure antifreeze diluted with distilled water(usually the lower cost option).
Dead Parrot is offline   Reply With Quote
Old 11-09-2022, 01:41 PM   #5
44SAA
Thanks Parrot. Bought new rad and it’s not hooked up yet. Figure it’s smart to flush w/o contaminating new rad
Old 11-09-2022, 05:56 PM   #6
kwmech
Have a drain pan ready, it will dump at least a gallon per side
Old 11-09-2022, 06:18 PM   #7
44SAA
Yanked one out- couldn’t get the other. Gonna quit while I’m ahead.
Old 11-09-2022, 07:12 PM   #8
Dead Parrot
IIRC - they are 3/8" pipe thread. If you damaged the one you got out, should be easy to find a replacement at a hardware/plumbing store. I think some older ones were 1/2" thread with a 3/8 square drive.
Old 11-09-2022, 08:59 PM   #9
kwmech
1/4'' pipe thread and 9/16'' hex. If replacing, use brass and don't crank it down as hard
Old 11-21-2022, 01:27 PM   #10
GRADYS Performance
GRADYS Performance's Avatar
The time and effort required to remove BOTH plugs and get out what you do not want in the new radiator will be well spent.
GRADYS Performance is offline   Reply With Quote
