Old 11-07-2022, 05:45 PM   #1
skokie
skokie's Avatar
Headlight relay
I was reading this post http://67-72chevytrucks.com/vboard/s...highlight=horn and have put this on the list of things to do to my truck. Saw this on lmc truck https://www.lmctruck.com/1967-72-che...dlight-harness
Has anyone used the one from LMC?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-07-2022, 06:45 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Headlight relay
I got mine from there. It's working fine, so far. It's been about 1.5 years since installation.
~Steven
Simi Valley, CA
Old 11-07-2022, 06:48 PM   #3
72SB
Re: Headlight relay
Yes, same as mine. Here is my thread about it
https://67-72chevytrucks.com/vboard/...dlight+harness
Makes not only headlights brighter, but all other lights also
72SB is offline   Reply With Quote
Old 11-07-2022, 07:19 PM   #4
skokie
skokie's Avatar
Re: Headlight relay
Thanks for the post. How did you tap into the headlight wires? Is there connectors that come with it etc? Do you have more pics of the installation?
Thanks!
68 build thread
Old 11-07-2022, 08:33 PM   #5
72SB
Re: Headlight relay
Install is very simple. No cutting any wires. Just mount the relays where I did or on PS of core support if you want. Simple install steps come with harness
Mount relays (I drilled 2 holes in fender lip)
connect harness + wire to the + buss on PS fender by battery
screw ground wire to fender
unplug PS headlight and plug it into harness (marked plug)
plug the harness plug into PS headlight
run harness under core support to DS
Unplug DS headlight (it will be left unused)
plug harness plug into DS headlight
Open beer, admire work
I have one of these in my 67 Camaro also (different brand). All the older cars had full headlight draw go through the switch, so this mod is beneficial to any car/truck of that era
Old 11-08-2022, 10:09 AM   #6
MARKDTN
Re: Headlight relay
These kits are great. I would find one that has the following: at least 2 relays, 1 for high beam and 1 for low beam. Real high quality 5-pin relays made by Bosch, Hella, or Tyco. No offshore China relays (sealed Delco oval relays would also be acceptable-but not square). Actual real relay sockets, if it just has female spades for the relays, pass. Would be nice if the sockets had a mounting tab. Good quality wire and nice loom. Be sure to create a rock-solid ground. You are replacing-or at least supplementing-the factory ground for the headlights with this harness. If you do that you should have something that will last another 50 years.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 11-08-2022, 10:25 AM   #7
72SB
Re: Headlight relay
I wish there was one of these harness that is made in USA, maybe there is.
The one I got for my Camaro from Speedway was in a plastic zip loc bag, no printed instructions but these things are frankly self-describing on how to install. I assume someone made the Speedway one here....but were "offshore" parts used, IDK.
So far, for me both the Speedway one and the LMC one (which is clearly packaged as being from China) are working. YMMV
Old 11-08-2022, 01:00 PM   #8
RichardJ
Re: Headlight relay
Those kits seem to be nice, but you are adding 20 feet of extra wires around the radiator support. I added one 12 v wire from the battery junction block across to the driver side fender. I wired the relays like was described in the first post of the link provided by the OP in this thread. Less complicated and far fewer excess wires.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 11-08-2022, 01:21 PM   #9
72SB
Re: Headlight relay
well a few ways to skin this cat, rolling your own setup is fine
Not sure about your 20' math of extra wiring....
with a harness pre-made you are capturing the high volt, 12vdc, from the buss terminal on PS fender next to battery so that eliminates it coming all the way from the headlight switch to both L&R headlights but the wire running across the core support, IMHO is shorter overall of the 2 eliminated from headlight switch
IMHO either way a non-issue which method you chose. The main reason is to relieve the full draw load of headlights from the headlight switch itself and turning it into a relay trigger to activate the buss bar +12vdc source for headlights
Old 11-08-2022, 01:44 PM   #10
RichardJ
Re: Headlight relay
It looks like 20 feet to me and this is just for a two light chevy.
The other link in the first post for LMC shows the guy removing the battery, battery box and loosening the radiator. In the end, they ended up with the battery wiring in the screen capture shown below.
Sorry, I don't want any of that.
Old 11-08-2022, 02:19 PM   #11
skokie
skokie's Avatar
Re: Headlight relay
I have been bitten by offshore stuff before. I am thinking about piecing something together and make my own harness. Thanks again!
68 build thread
Old 11-08-2022, 02:34 PM   #12
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Headlight relay
With my first truck I went to the junk yard and gota couple realys froman old Dodge Caravan and with Instructions from MAD Electricals site and did the headlight upgrade bt this time I bought the American Autowre Kit, in 2018, and havent installed it yet.
https://www.americanautowire.com/sho...ncer-relay-kit
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-08-2022, 04:15 PM   #13
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: Headlight relay
If one springs for the Holley retro headlights do those need this relay option?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 11-08-2022, 05:12 PM   #14
72SB
Re: Headlight relay
a relay harness will benefit any lamp type used...with that said the Holly LED's are quite bright
Old 11-08-2022, 05:25 PM   #15
72SB
Re: Headlight relay
I would never do a hack install like the one shown in the pic of the LMC one you posted. Never connect an AUX lead wire to main battery post. Use the + Buss on the fender next to battery.....typically a good + battery cable has an AUX wire that feeds this aux buss and are themselves a fusible 30amp link
I did remove the 2 radiator hold down brackets to run the harness in the core support but never had to move the radiator itself. Removing battery makes it easier to unplug PS headlight and access the AUX buss connection
These headlight relay harnesses are very simple, and one can make their own. AAW stuff, IMHO, is always solid stuff. There are also a few independent "wire guys" who make this stuff. Gary @ innovative wiring makes great stuff. IDK if he does make headlight harness but his (battery cables, EL fan relay harness, MAF extensions, etc) are excellent quality
Old 11-08-2022, 07:22 PM   #16
Southcity
Southcity's Avatar
Re: Headlight relay
No relay required when running any LED headlight. I've tested this on my two Suburbans with Holley/Retrobrights and United Pacific. One with relay, one without, no change in LED light brightness or performance.
If running stock headlights or H4 upgrade, relay setup is highly recommended.
It's worth mentioning that the relay setup does take the load off the headlight switch so regardless which headlight you run (stock, H4 or LED), it's an upgrade.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 11-08-2022, 07:40 PM   #17
skokie
skokie's Avatar
Re: Headlight relay
What kind of LED headlights are you running?
Thanks!
68 build thread
Old 11-08-2022, 08:23 PM   #18
Southcity
Southcity's Avatar
Re: Headlight relay
K10 = Holley Retrobright
GMC = United Pacific
Both perform great but I'm liking the Retrobrights for their stock-lens look
Old 11-09-2022, 07:34 AM   #19
biketopia
Re: Headlight relay
Shooo for $200 EACH I'd try a pair of conversion lenses and some amazon or ebay LED bulbs 3 or 4 times over. I'm sure they're nice, but $400 for headlights is a bit much.
https://www.amazon.com/IPCW-CWC-7006...01OMEPEU&psc=1
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 11-09-2022, 08:04 PM   #20
jumpsoffrock
Re: Headlight relay
I wear glasses, don't have good vision. I have been driving old cars with halogen headlights for 15 years and I've never almost killed myself or someone else.
Original headlights work for me.
jumpsoffrock is offline   Reply With Quote
Old 11-10-2022, 12:31 AM   #21
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Headlight relay
Were halogen headlights OEM in '67 to '72? I wear glasses, too.
~Steven
Simi Valley, CA
Old 11-10-2022, 09:33 AM   #22
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Headlight relay
Nope, just the old standard sealed-beam headlamps. Not sure when halogen bulbs became the norm.
I wore glasses from age 7 until I got contacts at 19. Since cataract surgery several years ago, I now just use readers. Improved lighting has always been a good thing for me, no matter my age or vision correction.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-10-2022, 12:22 PM   #23
Wrenchbender Ret
Re: Headlight relay
Halogens became popular in the early to mid 80's.
I can't see any advantage to using relays with LED lamps.
George
Wrenchbender Ret is offline   Reply With Quote
Old 11-10-2022, 12:38 PM   #24
biketopia
Re: Headlight relay
George
Some LED set up's pull decent amperage. Mainly in headlight applications, some sort of load to build up heat is used to help keep them from fogging or icing up in poor weather conditions.
Old 11-10-2022, 06:14 PM   #25
skokie
skokie's Avatar
Re: Headlight relay
Thanks for the ideas. I will look into both the LED headlights and the relay conversion.
This is why this board is AWESOME!!
68 build thread
