![]() Join Date: Mar 2011
WTB POWER Steering pump
mine leaks I don't need the brackets would like it with pulley attached also will buy new if someone has a part # I looked at JEGs and Summit not sure if they are compatible I have 1967 SBC 327 camel back heads my original brackets bolt up nice to the block and Motor mount I don't want to change mounts I have a pump off a 305 different set up won't work with my brackets thanks in advance
Jess
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
![]() Join Date: Dec 2017
Re: WTB POWER Steering pump
These are rebuildable, and kits very reasonable. The only special tool is to pull the pulley, and available for "loan" at most parts stores. I was going to rebuild one recently, but found the shaft and bearing was very worn. someone had ran the pump dry, and kept running apparently, but I found a used one at a swap meet. There are some you tube videos on the rebuild. In case you want to tackle and save a few $$ like me, and avoid some of the junk rebuilts.
Thanks I think the tank itself is leaking not sure and not sure how to test that
"Trucks with Class"
![]() Join Date: Jul 2000
Check with CPP and others for new tanks. New pump kits come with the O-rings, and that usually cures them.
I did this a m and purchased new thanks very much to all
I think I have that, I will send you pic tomorrow.
| Bookmarks |
