Old 11-11-2022, 12:30 PM   #1451
Gregski
Gregski's Avatar
Re: My Dusty 71 GMCe Electruck
a little shipping update on that master cylinder
Gregski is offline   Reply With Quote
Old 11-11-2022, 12:39 PM   #1452
Gregski
Gregski's Avatar
so lessons learned by doing any project any "build" the devil's in the details and you can get 80% of the big stuff done in 3 weeks and then spend months chasing the small stuff, so here we go, lets get it
I think it's a good idea to have a brake and an emergency brake before taking Electron for a spin around the block just in case things get exciting
so the new transmission seems to be longer than the TH350 or at least that's how it sits under the cab, so The Greg needs to extend the parking brake linkage 6"
on my '69 the driver side has the adjustable fine threaded rod like so
Old 11-11-2022, 12:43 PM   #1453
Gregski
Gregski's Avatar
the other side the texter's side has a fixed length mushroom double headed rod which I decided to cut off one end and welder on a 6" grade 8 bolt with a standard hex head (this head has to be small enuff to fit through the hole / slot in the frame rail)
I think I used the belt and suspenders method on this, where first I weldered up the bolt to the rod, then ground that flat(ish) then slipped the steel sleeve over it and bugger welded that as well
Old 11-11-2022, 12:44 PM   #1454
Gregski
Gregski's Avatar
The curse of the if I touch it and remove it I better clean it, inspect it, MEDIA BLAST it, and POWDER COAT it continues...
Old 11-12-2022, 05:43 PM   #1455
Gregski
Gregski's Avatar
got the new tailgate on, fit great, good quality piece, only trouble was the left (driver side) round hinge thingie had a bit of a slight imperfection in it that we gently persuaded with a punch to get the lower hinge to go smoothly inside it
Old 11-12-2022, 05:46 PM   #1456
Gregski
Gregski's Avatar
getting the fiberglass rear rollpan to fit was a bit of a stretch
Note To Self: get new bedsides
Old 11-12-2022, 09:55 PM   #1457
72 tigger
72 tigger's Avatar
Ebrake setup should work well. Like the tailgate
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 11-13-2022, 11:35 AM   #1458
layinrocker65
layinrocker65's Avatar
Time to put disc brakes in the rear with Tesla electric parking brakes?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 11-13-2022, 02:16 PM   #1459
Gregski
Gregski's Avatar
thanks mate I hope so
Old 11-13-2022, 02:17 PM   #1460
Gregski
Gregski's Avatar
ha ha, don't temp me, you know a complete tesla rear wheel drive unit would totally eliminate all my drive shaft woes
Old 11-13-2022, 02:19 PM   #1461
Gregski
Gregski's Avatar
managed to perfectly align the brand new fiber glass roll pan to the bad body lines of the bed sides and luv the roll pan look, whacha all think?
Old 11-13-2022, 08:27 PM   #1462
zicc1835
zicc1835's Avatar
I’m a fan of the pan…….
zicc1835 is offline   Reply With Quote
Old 11-13-2022, 10:02 PM   #1463
CG
BlahBlahBlah
My son is a commercial electrician, he has this sticker on his hard hat.
Old 11-13-2022, 10:31 PM   #1464
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Originally Posted by CG View Post
Remember Kids ... My son is a commercial electrician, project manager. He has this sticker on his hard hat.
I laughed at the sticker 'til I cried!
~Steven
Simi Valley, CA
Old 11-15-2022, 12:06 PM   #1465
Gregski
Gregski's Avatar
so this could explain the soft 2018 Honda CR-V brake pedal
Old 11-15-2022, 12:08 PM   #1466
Gregski
Gregski's Avatar
more detail in this video EV Update Honda CRV Bad Brake Master Cylinder
Old 11-15-2022, 11:11 PM   #1467
doowopper
My understanding is that brake fluid is hygroscopic so perhaps that vehicle had been in a flood or sumpin.
buddy
doowopper is offline   Reply With Quote
Old 11-16-2022, 11:09 AM   #1468
CG
BlahBlahBlah
All the blasting and coating you do makes me want to get a cabinet and an old oven. Blasting and powder is something you can do all winter without worrying if your shop is warm enough to paint in. Or maybe move in next door to you =)
Old 11-16-2022, 12:00 PM   #1469
Gregski
Gregski's Avatar
ha ha, it will change your life, but it is not a cheap sport, I would say minimum $2k to enter the arena, and yes guys will argue that till they are blue in the face, but I've done this for months so I know what I am talking about, lol
anyway I keep my media blasting cabinet outside so in my case media blasting is not an all year round sport as the media gets moist/wet
as far as oven advice see if you can land a larger commercial pizza oven or one of them stackable double deckers that you can start off by using just one half and then join them together to bake longer items
as far as moving next door, two words for you: H.O.A.
Media Blasting Advice: Replace The Glass
Old 11-16-2022, 12:26 PM   #1470
Gregski
Gregski's Avatar
the good news is the new used $80 dollar Honda CR-V master cylinder showed up last night and appears to be much more better
Old 11-16-2022, 01:17 PM   #1471
biketopia
I'm still curious to see if you'll have enough bore and stroke to operate the C-10 brakes effectively
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 11-16-2022, 01:31 PM   #1472
Gregski
Gregski's Avatar
yeah, me too, my friend Patrick, our friend Patrick inputed all the measurements and lengths of both the Honda CRV and the C10 into his wrist watch calculator and it spit out that the stroke or piston travel is almost identical, it was identical to the thousandths of an inch
Old 11-16-2022, 02:34 PM   #1473
pjmoreland
pjmoreland's Avatar
The amount that the piston moves compared to the amount the pedal foot pad moves is the same between the Chevy and Honda brake pedal assemblies. We haven't measured the stroke or bore of the Honda master cylinder yet. It would be good to measure the stroke and bore of both the Honda and Chevy master cylinders for comparison.
pjmoreland is offline   Reply With Quote
Old 11-16-2022, 08:22 PM   #1474
yuccales
yuccales's Avatar
I cried after I saw what a two month bill was!
yuccales is offline   Reply With Quote
Old 11-17-2022, 01:34 PM   #1475
Gregski
Gregski's Avatar
got some numbers:
SOME HONDA CRV MASTER CYLINDER SPECS
the 2018(ish) Honda CRV master brake cylinder piston is 1" in diameter (aka bore) and travels 1.5" (aka stroke) in and out of the tube thingie
