Old 11-20-2022, 12:48 PM   #1
chillware
Re: Sound Proofing/Deadening The Cab?
Originally Posted by JohnIL View Post
Chilli,
Which of the Noico products did you use? Was it the 80mil black/foil material or one of the thicker Noico Red products?
Thanks.
John
This is the kit I used..
Noico 80 mil (2 mm) 36 sqft (3.4... https://www.amazon.com/dp/B00URUIKAK...p_mob_ap_share
My build thread: '66 Chevy
chillware is offline   Reply With Quote
Old 11-21-2022, 10:51 AM   #2
JohnIL
JohnIL's Avatar
Thanks Chilli. That's almost identical to the Kilmat product we used in my son's El Camino. We followed the directions and covered 60%-70% of the floor pans, firewall, and roof. It definitely took the tin can resonance out of the cab, but it didn't really "sound proof" it very much. When I do the C10, I'll aim closer to 100% coverage, like you did. Then, I'll probably go over that with one of the thicker 394mil sound/heat barrier products.
John
1965 C10 Long Bed Fleetside
SBC 350 and Saginaw 4 Speed
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=838676
JohnIL is offline   Reply With Quote
Old 11-21-2022, 11:15 AM   #3
JohnIL
JohnIL's Avatar
Update: New Door Seals
Just before the winter weather hit the midwest, we had a warmish weekend. I took advantage of a rare free Saturday to install new door seals on the C10. I used push-on style seals from Brothers. The new seals are definitely tighter than the crumbling original seals and, just like the clutch fan, the new seals changed the tone/drone of the cab, but they didn't do much to quiet the cab down.
With the new door seals installed, I took the truck for another test drive. At 60mph, no heater fan, no radio, the sound level was still at 72db. The one variable was the wind. There was a 20mph cross wind that day that very well may have added to the cab noise. My previous test drive sound tests were done on calm days. I'll test the sound level again if we ever get another calm day...
John
Build Thread:
