Old 11-19-2022, 06:54 PM   #1
v30crewcab
v30crewcab's Avatar
stock fans temp?
stock 03 van computer thats vats deleted and nothing else, what temp does fan one and fan two turn on and off at?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 11-19-2022, 10:47 PM   #2
mongocanfly
mongocanfly's Avatar
Re: stock fans temp?
That would be setup by the tuner..
Mine is set fan1 at 175, fan2 at 185..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-19-2022, 11:44 PM   #3
v30crewcab
v30crewcab's Avatar
well theres a stock setting, if you just turn the fans on. just can't find what it actually is. what is the factory setting for one thats oem electric fan, like an 05 or 06 tahoe?
71 longbed 5.3 4l80
Old 11-20-2022, 12:27 AM   #4
mongocanfly
Found this with google... not sure how accurate it is
Factory temp settings are low speed on at 226 degrees and off at 219 degrees. High speed on at 235 degrees and revert to low speed at 226 degrees. Both fans run at low speed and high speed and fans are commanded off by the PCM when the vehicle speed exceeds 35mph.
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-20-2022, 09:36 AM   #5
v30crewcab
v30crewcab's Avatar
thanks. my low fan is coming on and staying on. need to see what temp its coming on at. truck seems to be running warmer but not overheating. not sure whats happening.
71 longbed 5.3 4l80
Old 11-20-2022, 11:52 AM   #6
ls1nova71
ls1nova71's Avatar
An '03 van doesn't have electric fans, so you would have to have them enabled in the tune.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-20-2022, 01:44 PM   #7
v30crewcab
v30crewcab's Avatar
yes it was a stock computer sent to bp to unlock it and turn on the fans. they leave the stock settings just unlock it.
71 longbed 5.3 4l80
Old 11-21-2022, 08:48 AM   #8
Joyridin
Huh? It is an 03. There is nothing to unlock. Do you mean they enabled the fans?
Joyridin is offline   Reply With Quote
Old 11-21-2022, 10:55 AM   #9
mongocanfly
Joyride, gotta get the vats unlocked/disabled or whatever you want to call it
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-21-2022, 11:09 AM   #10
Joyridin
Ok. I was thinking of literally unlocking the ECU like they do on newer vehicles.
