Old 11-21-2022, 09:26 PM   #1
May70
May70's Avatar
Class 4 Trailer Hitch
I found some others using a Curt 14082 trailer hitch. That hitch setup seems like it could be a little wider but I can make it work, I read the holes are 31 1/4" between centers. If I use that hitch ill be reinforcing the rear of the frame since it just bolts to the lower flange.
I want a class 4 so any lesser ratings are off the table. What hitch are you running and did you stiffen the frame? Pics?
Im planning on putting a fuel tank back there so trying to make compatible decisions and get both of these items ordered.
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 11-21-2022, 11:14 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Class 4 Trailer Hitch
This is an Old thread so here is an idea.
#29 and #42
Link: https://67-72chevytrucks.com/vboard/...r+hitch&page=2
84 Chevy K-20
Old 11-22-2022, 01:59 AM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Early Classic Enterprises Stainless Steel Tank I bought in 2003 and the Hidden Hitch they sold and both installed last year in 2021.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 11-22-2022, 01:09 PM   #4
68 C10 Driver
Nice install! I think I am also going to do a hidden hitch as well.
68 C10 Driver is offline   Reply With Quote
Old 11-22-2022, 05:32 PM   #5
72c20customcamper
72c20customcamper's Avatar
Had one made for my truck by a local fabricator and good friend . Truck already had massive brackets for the step bumper made out of 1/4 inch plate we just added to it .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 11-22-2022, 06:28 PM   #6
LNP
I installed a 37042 Reese multi fit class III hitch in my 69 C-10. I moved my gas tank lcation to the rear so the crossmember you had to remove for the gas tank to go in I welded it to the very rear of the frame so the last crossmember is still there. I used 1/4" plates and drilled them for the hitch to bolt to them and the frame rails. This kept the hitch in the same postition as it was when it bolted directly to the frame.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
