![]() Join Date: Mar 2016
Side trim mounting holes
Will all the holes for my upper and lower moulding be in a perfect line from grill to gate if they are correctly aligned, or are some holes offset? Anyone have drawings with dimensions? Thanks in advance.
Re: Side trim mounting holes
Are you thinking of adding the trim?
And your truck has no holes. Well me too. Subscribed Ttt...
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Here you go.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
More
and even more.
Wow, thank you!
Mine has holes for trim already, but the trim never aligned properly. I suspect it is bad body mounts, so once they are replaced, I assumed they should all line up. We’ll see. Looks like they should. |
![]() Join Date: Feb 2009
Only problem with the assembly manual is it doesn't provide a starting point, otherwise know as initial reference points. For example, the top image (post 3) reads 30" & 10". 30" & 10" from where?
I'm definitely subscribed, because I'm adding uppers and lowers. This subject has come up many times over the years. Ideally, someone might provide the vertical and horizontal measures for the outer holes for one side of the truck (tops & bottoms) from definitive edges. For example: The rear edge of the door to the center of the first hole is: The bottom rear edge of the door to the center of the first hole is: The front edge of the door to the center of the first hole is: The bottom front edge of the door to the center of the first hole is: Yeah, that's just one of 10 pieces, and images would go a long way. Takes some doing. Makes me want to tear off the moldings on my driver...... ![]() If ever someone could do this, then we'd all know the exact locations.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-24-2018 at 08:10 PM. |
The clips slide in the moulding so the horizontal measurements aren't real critical. I just held the lower molding up against the truck and figured out where the holes would be to make it look right. I don't have the upper molding but it would be harder to locate vertically because you don't have a body line adjacent to the molding for reference.
![]() Join Date: Dec 2013
Sub'd
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
![]() Join Date: Apr 2013
Subscribed
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
#11 | |
If the hardware is centered, which I suppose it must be, then the height of the holes should be easy to figure out. Tape the trim up, mark the ends and snap a chalk line, for example. For what it's worth, the lowers look to be 3/8" below the body line. Think I recall reading that too. Upper bed trim is a bit different, because it's slopes down toward the rear. From what I gather, the uppers start with the door, placed level. Judging by my 72 LWB Super, the upper door trim sits against the door lock, or it's off by a pinch. That said, can't swear my trim is a solid reference, some holes have rivets ![]() In other terms, height seems fairly straight forward, less upper bed trim. But my 72 LWB also has the upper bed trim. Just as well to measure. LWB or SWB, the rear hole should be the same height. Horizontal seems a bit more tricky to me, uppers and lowers. It's probably straight-forward once done. On a side, might be interesting to note, the number of holes does not need to be factory, for a "factory" build. I'm guessing here, whether or not they drilled the holes anyway is beyond me. Could also be the trim pieces I've got are GM replacements (i.e., NOS, but not factory)...................... I have all the NOS pieces, which included all the clips and such. At some point in time, can't say when, 3M stickers were added to the inventory. Somewhere around here I have all the parts listed, with comparisons to the assembly manual.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-25-2018 at 01:14 AM. |
Looks like a big job and lots of patience.
Thanks for the pics those are great. I think I'll save for last project.
My trim was all NOS with clips included as well. I found the aftermarket clips actually work better than the NOS clips.
There is someone on the blazer forum that used 3m tape directly on the trim without using the clips worked out pretty good.
#15 |
![]() Join Date: Apr 2021
#16 | |
#17 |
#18 |
That's the million dollar question. No one really knows where the factory fllor is in reference to the drawing. If you can locate one factory hole, you can reference everything from there. That is the way I did mine. I had an old bedside that had trim, so I used a fixed laser to transfer those holes to my truck. So many inches from the top of the bed and so many inches from the front of bed, etc. You can follow the drawings from that point.
