Old 11-27-2022, 09:54 PM   #1
Yamariv
Yamariv's Avatar
New Rear Drums - Help with what size to order
Just about to pull the trigger on a set of drums from Rock Auto and am worried about getting the right size.
The ones I have chosen say 11x2", the other options don't say a size. I have the base model truck with a 5 bolt wheel and a 12 bolt rear end.
I've just removed a rear tire and measured across the front of the drum and I get about 11.75 inches. The drum depth is almost 4 inches.
Is this the right size to order? Or is the stock size the drums with no measurements in the listing?
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
Old 11-27-2022, 09:56 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: New Rear Drums - Help with what size to order
The brake shoe width
KQQL IT is online now   Reply With Quote
Old 11-27-2022, 10:27 PM   #3
Yamariv
Yamariv's Avatar
So would 11x2" inch be the right size for my setup?
3 Core Radiator
Old 11-27-2022, 10:42 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Is it possible for you to take a brake drum to a local store and tell them what you have, along with the drum? Maybe take both drums and the shoes along so that they can figure out what you have?
~Steven
Simi Valley, CA
Old 11-27-2022, 11:39 PM   #5
3757chevy
3757chevy's Avatar
If you take a drum off measure across the shoes and the width of the shoe or you can measure inside the drum the diameter and the depth where the shoe has been riding. I hope this helps.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 11-28-2022, 01:17 AM   #6
franken
NAPA shows one drum for a 1971 Chevy C10 so I wonder if there's an issue.
Old 11-28-2022, 01:53 AM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The 71 and 72 C/10's with the 12-bolt axle have 11" drums with 2" shoes...5x5 lug pattern.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-28-2022, 01:57 AM   #8
3757chevy
3757chevy's Avatar
I only think they used 11x2 on both C10 5 lug and K10 6 lug . I don't remember other sizes used that year.
MIKE
Old 11-28-2022, 01:58 AM   #9
Ironangel
Ironangel's Avatar
Yes, as long as the factory 12-bolt axle is still there, you should be good to go with 11" drums with five lug holes. The brake shoes are 2" wide.
"Two Seventy Two's"
02 3/4 ton Express
Old 11-28-2022, 03:25 PM   #10
Yamariv
Yamariv's Avatar
Awesome, thank you gentlemen for all your help!! Yup 12 bolt is still there, 5 lug tires Ill order those up!
3 Core Radiator
Old 11-28-2022, 03:55 PM   #11
HO455
HO455's Avatar
Personally I would measure them. I have swapped numerous rear brake set ups over the years to improve braking. Your truck is 50 years old and things may have been swapped somewhere along the line.
RIP Bob Parks.
Old 11-28-2022, 03:58 PM   #12
72SB
might want to order new wheel cylinders also...or rebuild kit and hone yours. IMHO they are fairly cheap so just get new ones. I also got my 72, 5 lug rear brakes from RA
If the center soft line is old, replace it also
72SB is offline   Reply With Quote
Old 11-28-2022, 05:27 PM   #13
Yamariv
Yamariv's Avatar
Oh yeah for sure, I'm doing the full brakes, wheel cylinders and center brake line. Everything in the front too, calipers, disks etc. 50 years, time for some new stuff
3 Core Radiator
