Old 11-27-2022, 09:29 PM   #1
Stover93
71 K10 auto shift linkage bushing
Does anyone have a source for the plastic bushing where the shift rod attaches to the trans linkage… at the bottom end of the rod where the wire clip/cotter pin is?
All I seem to be able to find is the whole kit with a bunch of parts I don’t need.
Stover93 is offline   Reply With Quote
Old 11-28-2022, 02:11 PM   #2
Toro
Toro's Avatar
Re: 71 K10 auto shift linkage bushing
Would need more info, and to compare what original looks like.
https://www.summitracing.com/search/...word=RNB-02373
Toro is offline   Reply With Quote
Old 11-28-2022, 07:34 PM   #3
Stover93
That’s the one at the top on the column. Can’t seem to find the bottom one at the transmission. I’ll check the trusty ol help section at Napa.
Old 11-28-2022, 07:39 PM   #4
Louisvillekytruck
Like to know too
Louisvillekytruck is offline   Reply With Quote
Old 11-28-2022, 07:40 PM   #5
pjmoreland
pjmoreland's Avatar
Here are some images from the parts catalog. I'm assuming you're looking for item #6. I believe the GM part number for that bushing/grommet is 3833107. A quick google search for that part number brings up this result.
https://shiftworks.com/products/univ...inkage-grommet
I believe item #20 is the grommet that goes in the arm that sticks out of the bottom of the steering column, and it appears to be part number 3975131.
pjmoreland is online now   Reply With Quote
Old 11-28-2022, 07:52 PM   #6
Louisvillekytruck
Thank you great information
Old 11-28-2022, 09:37 PM   #7
Stover93
Thanks PJ. Amazing what having a part number will do. Much appreciated.
