Old 12-02-2022, 08:17 PM   #1
kwmech
Re: What is this wire?
Is there 12v there either batt or ign? Looks like a bullet plug-maybe for the cig lighter?
Old 12-02-2022, 10:56 PM   #2
68 C10 Driver
I do not have the battery connected yet, not that far along. The cigar lighter has a red wire that heats the element, ground is achieved through the mechanical connection at the dash.
I am just real stumped as to what this wire connects to. The only thing I do not yet have installed is the radio...radio ground?
I appreciate the responses.
68 C10 Driver is offline   Reply With Quote
Old 12-02-2022, 11:17 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Grasping at straws here. Do you have this ground wire? It is the ground for the cluster. You could use a Multi-Meter (OHMS) and see if your wire connects to that space on the cluster connector.
LockDoc
Leon
Old 12-03-2022, 10:28 AM   #4
68 C10 Driver
LockDoc
The cluster ground is connected, that one is easy as it has that odd clamp connector. I will look for the schematic that came with the harness. I guess I got ahead of myself by wrapping the harness in harness wrap...I really don't want to cut that open.
I guess I will chase that wire down using my multimeter.
Thanks again guys!
Old 12-06-2022, 04:54 PM   #5
68 C10 Driver
Mystery solved, the wire in question is from the under dash air conditioners wire to the binary switch (back in the day it went direct to the compressor.
I just had to unravel the harness tape to follow it. Thanks to all that offered their thoughts and guesses.
