1962 looking for parts
Aloha all
1962 seems to be a hard year to get parts. I am looking for the control arm seals. Most places sell the complete control arm but that is silly when you only need the seal, They do sell the 63-66 seal. Will the 63 seal work? I am also looking for the lower control arm bumper, rear bumpers, and exhaust hanger kit. any ideas where to shop. I have tried pony boys and classic parts and a lot of internet searching. Thanks for any tips 1962 6cylinder fleetside long bed Last edited by keith808; 11-18-2022 at 12:10 PM. Reason: truck info |
Re: 1962 looking for parts
I just went through this with my 60. I found ecklers has the lower control arm shafts. 60-62 is a different style than the 63-66 control arms due to the torsion bars.
I know, I did not know when I bought the 62 that it would be such a pain to find some parts.
If anyone has a good source please let me know. KFisher |
Parts are easier to find now than 10+ years ago. Capitan Fab has good stuff. Exhaust is better from shop. You might get lucky with Walker parts. By all meas check my build. I use Speedway Motors alot. Classic Parts.com, Classic Industries, for 6 cyl... 12bolt.com
https://customfab-cda.com/
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Get 1 of these manuals
https://www.amazon.com/1960-1966-Fac...8-1bf73812adbd
Disk brakes...
https://www.performanceonline.com/19...caAlo_EALw_wcB
I went through the same problems with my 62. If I had to do it again I would do a front suspension swap with a 73-80 c10. Parts are easier to get.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 Last edited by 62 Barnfind; 11-25-2022 at 04:08 PM. |
I have almost all the suspension parts off my '61. Most are pretty tired. Shipping from Canada would be rough.
I went 73-87 front end.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
![]() ![]() Join Date: Apr 2012
The control arm seal GM part numbers for 60-62 are 3762960 lower and 3762959 upper .Control arm Bumper lower 3762981 , upper 3773361 . As mentioned above , the Assembly manual will give you the GM part numbers for exhaust hangers .
https://67-72chevytrucks.com/vboard/...1966+gmc+panel IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Thank you everyone. The advice has been very helpful. Much appreciated.
When I searched a couple years ago, I couldn't find any lower control arm bumpers for '60-'62. If you're a purist, maybe some place like Steele could revulcanize yours.
It's not this place or that place that doesn't have a lot of '60-'62, it's every place. I've looked at many, many vendors; there are less parts available for '60-'62 than any other year Chevy truck since 1946. It has been getting a little better over the years. Accept it or swap the chassis. |
| Bookmarks |
