Old 12-07-2022, 09:26 PM   #1
mtnxtreme
Spartan Locker in 65 12 bolt Issue
Bought a Spartan Locker for my 65, after I install the side couplers where the thrust washers were , the axles and c clips,the center pin does not fit between the axles. Spartan is telling me the 65 had an early narrow carrier and I cant use the locker but have to buy a whole new wide style carrier with limited slip, I'm pissed, $350 down the drain, has anyone ever heard of this and maybe know some option's, I really don't want to put my spiders back in.
mtnxtreme is offline   Reply With Quote
Old 12-08-2022, 06:08 PM   #2
mtnxtreme
Re: Spartan Locker in 65 12 bolt Issue
No one ? I'm at a loss. Trying to get thru to Spartan ? Randys is a battle. I hate to have to do a new carrier and have to reset the clearances etc.
Old 12-09-2022, 12:15 AM   #3
cwcarpenter98
cwcarpenter98's Avatar
I still have an open diff in mine, so I'm no help here.
I don't know if it would be detrimental to the integrity of the axle shafts, but could you shave down the ends a little until the pin fits through again?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 12-09-2022, 08:35 PM   #4
mtnxtreme
You would have to take so much off the clips wouldn’t hold
Old 12-09-2022, 08:55 PM   #5
mtnxtreme
You would have to remove so much from the axles the C clips couldn't hold. I was thinking maybe c clip eliminators, but I think they are expensive and need machine work.
