Old 08-07-2004, 12:51 PM   #1
skid
3/4 ton brake booster
Will a 3/4 ton brake booster bolt right up in place of a 1/2 ton booster? I have read that they will provide more stopping power, but am unsure whether they will bolt right up. I am going to buy one or the other today.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 08-07-2004, 01:22 PM   #2
FormerMember
Yes, they will.
I used one on my 71 Blazer.
MC is the same part number.
You may have to move or extend your brake lines. The booster is longer.
FormerMember is offline   Reply With Quote
Old 08-07-2004, 01:34 PM   #3
skid
Thanks Grendal
I found this article on ColoradoK5 as well...
http://coloradok5.com/forums/showfla...o/fpart/1/vc/1
Toys:
72 K5 Blazer
74 Vette
Old 08-07-2004, 02:14 PM   #4
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Great, another thing to add to the list of stuff to do
toddtheodd is offline   Reply With Quote
Old 08-07-2004, 03:33 PM   #5
FormerMember
Originally Posted by skid
Thanks Grendal
Yep, Ryan's a good guy.
Old 08-07-2004, 10:35 PM   #6
7gmc2
7gmc2's Avatar
i am noticeing that most of you responding to this post are blazer drivers.....is this a good idea for trucks too, or is this a really dumb question? great post though none the less....
1972 GMC Sierra Grande
7gmc2 is offline   Reply With Quote
Old 08-07-2004, 10:55 PM   #7
Sweet72
Sweet72's Avatar
When I converted my half-ton '72 GMC I used a booster from a 3/4 ton pickup and it worked great, till the old diaphram blew out. I can't believe the prices for new boosters!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 08-07-2004, 11:10 PM   #8
7gmc2
7gmc2's Avatar
thanks sweet72! sorry to hear the diaphram trouble, but glad to see it does apply to trucks as well......
Old 08-07-2004, 11:24 PM   #9
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Not the same
If you are talking about the dual diaphram, DB booster, 71-2, they do not use the same MC as the 1/2T. The hole is a much different depth and will not work. You have to use the matching 3/4T MC with the 3/4T booster....then the whole package will bolt in the 1/2T truck and work.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 08-08-2004, 01:22 AM   #10
dennis111
dennis111's Avatar
I am wanting to do the 3/4 ton swap on a 68' but believe the brackets are different than a 71-72 truck.
Should I use one from a 68' version instead? It looks like a dual diaphram too but carries a different part # in the parts catalog.
If I use the 68' diaphram, what master cylinder would I use for disk brakes?
Anyone done the swap on an older blazer/truck?
Dennis
68 GMC SWB Custom 1/2 ton, 2WD, 350 V8, PS, PB, 3-Speed, 3:08 12 bolt rear, tilt, tach, vac, cruise and more. . . .
dennis111 is offline   Reply With Quote
Old 08-08-2004, 01:43 AM   #11
skid
The 3/4 ton brake booster and Corvette master cylinder are in and well, let's just say I can lock all four tires up at 60 mph! I could hardly make the tires squeal at 10 mph before. A definate improvement! Much better pedal feel and modulation as well.
It wasn't quite a bolt in though. I had to extend the front support brace 1 11/16" (welded in a extension) because that is how much wider the 3/4 ton booster is over the 1/2 ton. The plunger rod that came with the 3/4 booster was too short as well. I had some 3/8 drill rod laying around that i measured and cut so that there was maybe 1/4 inch of pedal travel before the master cylinder moved.
The Vette master cylinder is almost identical to the stock m/c. The bore size is the same, and the ports are spaced the same, with just a little offset. I just tightened the lines, and the lines re-adjusted themselves. I loosened the lines on the combination/proportioning valve as well before I tightened the lines on the master cylinder to help them align.
All in all, a definate improvement that just took a little messing around to complete...
Toys:
72 K5 Blazer
74 Vette
Old 08-08-2004, 08:46 AM   #12
7gmc2
7gmc2's Avatar
ok now i'm confused? $*#@ at first this sounds like an easy swap, one booster for another. the link to the article gives me the same impression. i gathered that the master cylinder for the 3/4 ton was an optional swap. bottom line is i have a 1/2 ton 72 with disk brakes now. what do i need to do to make this work? 3/4 ton booster only, or 3/4 ton booster and 3/4 master cylinder package?
Old 08-08-2004, 10:22 AM   #13
toddtheodd
toddtheodd's Avatar
The way I understood the talk under that link was that you could use either. That it was more of how you wanted the pedal to feel.
Old 08-08-2004, 11:46 AM   #14
skid
7gmc2,
You can use your stock m/c. All you would need to do is extend the brace and make a new, longer, plunger rod (at least that was my experience). I used a Corvette (1974) m/c because I am going to use rear disk brakes eventually, plus I used my Vette to compare sizes so I knew it would fit.
A 3/4 ton m/c would not really make sense to use because the lines are backwards, with the rear brake lines at the front of the m/c.
Toys:
72 K5 Blazer
74 Vette
Old 08-08-2004, 01:39 PM   #15
7gmc2
7gmc2's Avatar
thanks for clearing that up for me skid! i too plan to go to an all disk set up so that is helpful to know. i wonder if there is a plunger rod that you can buy already the right length?
Old 08-08-2004, 02:35 PM   #16
skid
Actually it is pretty easy to make a plunger rod. You just need to measure how far it needs to stick out past the m/c mount. A long 3/8 bolt could be used for a plunger rod, just cut off the hex, and round of the m/c side on a grinder. I mounted mine in a drill and spun it as I ground it. This made it perfectly round.
Toys:
72 K5 Blazer
74 Vette
Old 08-08-2004, 02:42 PM   #17
skid
Just to add to my previous comments regarding the plunger rod:
Measure how far in the m/c piston the hole goes (remember to measure to the mount flange and subtract the difference). Place the rod in the booster and measure how far the rod sticks out. Subtract the difference
and cut the rod. I left a slight bit of clearance to give me a little pedal travel before the m/c piston moves.
Toys:
72 K5 Blazer
74 Vette
Old 08-08-2004, 04:04 PM   #18
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
It is very simple install and requires no mods or cutting. Take the complete 71-2 3/4T DB booser, brackets, rod, MC, prop valve---hook up your two lines to the prop valve---install it and run it. Don't mix or shim other parts. The rod will hook right up to your pedal. The pedal on PB hangs lower in the cab...that is normal and correct.
If you go to rear DB in the future, you will need a different prop valve.
The pictured Corvette style MC, prop valve set is made to work with both 1/2T or 3/4T boosters. It has a machined safe engineered insert for the two depths.
Phone: 360-956-7170
Old 08-08-2004, 04:38 PM   #19
nate68
I'm using a corvette master cylinder with a 68 3/4T Booster. everything works fine.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 08-08-2004, 09:13 PM   #20
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
My truck already had a 3/4 brake booster in it, it's the original one too. I never had any problems with the brakes. My truck also has the HD brake and suspension option.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 08-08-2004, 10:57 PM   #21
Southpa
Southpa's Avatar
I had no problems swapping. The pic shows the old 1/2 ton drum/drum setup converted to disc/drum setup. Notice 1/2 ton m/c for disc drum with 3/4 ton booster. No mods, shimming, welding etc. needed, it just bolted right up!
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 08-09-2004, 12:09 AM   #22
skid
Southpa, my Blazer has a support from the front of the booster to the firewall (it also has one on the back). I notice your picture doesn't show one. That is the piece that I had to extend. I also used a Corvette m/c for a future rear disk conversion. The 3/4 ton booster came with too short of a plunger for my stock m/c as well. Maybe there are different length rods for different applications.
Toys:
72 K5 Blazer
74 Vette
Old 08-09-2004, 02:49 AM   #23
Budweis
Geared for Collision
Budweis's Avatar
had some questions bout the vette mc but guess ill start a new thread on it so i dont hijack this one
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
